查看: 5723|回复: 0
AIRBFT气动避震 浙江嘉兴壹号汽车 大众CC VS莲花
发表于 2020-7-4 16:29:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
AIRBFT气动避震江嘉兴壹号汽车 大众CC VS莲花Airbft pneumatic shock absorber Jiangxing No.1 Volkswagen CC vs lotus
In a certain device, the main shock absorption of the gas is the shock absorption of the air. When the external vibration decreases, the stored internal energy is released in the form of kinetic energy through the movement of shock absorber components, so as to reduce or eliminate the vibration impact. Its function is like a shock absorber spring, only the deformation of the spring is replaced by the shrinkage and expansion of the gas volume.
