查看: 665|回复: 0
雷克萨斯LS430改装气动避震见证改装的完美蜕变HellaFlush风格
发表于 2021-6-3 16:07:53 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Lexus ls430 modified pneumatic shock absorbers witness the perfect transformation of hellaflush style
丰田汽车公司与丰田汽车(中国)有限公司计划在中国市场上率先推出第三代豪华轿车的旗舰之作──LexusLS430超级豪华轿车,实践车迷对完美豪华轿车的种种想像。新车型在6月6-12日在中国国际展览中心举行的“第六届北京国际汽车工业展览会”上进行全国公开首展。
Toyota Motor Company and Toyota Motor (China) Co., Ltd. plan to launch the flagship of the third generation of luxury cars in the Chinese market - Lexus ls430 super luxury car, to practice the imagination of fans on the perfect luxury car. The new model was exhibited in the 6th Beijing International Automobile Industry Exhibition held in China International Exhibition Center from June 6 to 12.
雷克萨斯LS430改装气动避震对于雷克萨斯的粉丝来讲,低趴也是不少人追捧的风格之一了,不一定要走浓浓的VIP风格,一套运动范的轮毂,加上一套可调高低气动减震,便可以玩转气动避震Hellaflush的最美风格改装……
Lexus ls430 retrofitting pneumatic shock absorbers for fans of Lexus, low lying is also one of the styles pursued by many people. You don't have to take a strong VIP style, a set of sporty wheels, plus a set of adjustable high and low pneumatic shock absorbers, you can play with the most beautiful style retrofitting of hellaflush pneumatic shock absorbers
Hellaflush has become an international appearance trend of refitted cars. With the development and progress of domestic refitted cars, more and more people accept it. HF model has become a symbol of taste
HellaFlush的主要特征:
The main features of hellaflush are as follows:
1. The central idea of hellaflush is offset is everything. The wheel hub uses an offset value that is more stretched than the normal value, so that the wheel hub is beyond the coverage of the body fender.
2. The distance between the wheel eyebrow and the wheel hub should be as small as possible. To complete this task, the car body should be lowered to a height that does not conform to the daily use, so that some HF style cars can't drive at all, so they have to use a trailer to pull the orz. As for how to lower the car body, there is no standard. Pneumatic shock absorbers, twisted teeth shock absorbers, short springs, or even modified sheep horns, you can do anything to achieve your goal.
3. As a result of the first two points, if the tire wants not to be rubbed and burst by the fender, it must use a specification narrower than the width of the wheel hub, so that the edge of the tire can be retracted so that it can be completely hidden in the fender. Of course, the fender can also be rolled in or expanded to a certain extent according to the protruding degree of the wheel hub.
4. If you want to have more attitude than attitude, you can't take the normal road for the inclination value of the tire. Take off at minus 2 degrees (that is, the upper part of the track is narrow and the lower part is wide). The method can be to adjust the inclination rocker arm, gasket and change the sheep's horn. In a word, we can't see eye to eye with normal people.
5. Tire stretch refers to the effect of the narrow tire installed on the ultra wide wheel hub. It's not easy to achieve this effect. Choosing a variety of tires should be strictly calculated according to the width of the wheel hub. Because, too wide hub with a narrow tire, when the tire inflation may dislocation, so can let the tire according to the correct position taut on the hub depends on the technician's modification level.
