查看: 855|回复: 0
奥迪RS6改装气动避震变身低趴姿态堪称完美
发表于 2021-6-3 14:34:39 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Audi RS6 refitting pneumatic shock absorber into low lying posture is perfect
奥迪RS6 Quattro,我们通常称呼其为RS6,是A6产品线中的高性能版本,其定位高于奥迪S6。这是一个重视运动的五门五座旅行车,由奥迪旗下的Quattro Gmbh股份有限公司开发并生产。
“RS“的缩写,取自德语:RennSport。直译为“赛车运动“,代表奥迪的顶级高性能水平,定位于“S“型奥迪加强性能车型系列之上。像所有的奥迪“RS“系列车型一样,奥迪RS6使用最新最先进的工程和技术,所以它可以被称之为一个光环车辆。其具有所有奥迪车型中最强大的发动机数据,甚至超越了体型更大的奥迪S8。此外,像所有的RS车型一样,奥迪RS6 [1]  使用“托森”出产的quattro四轮驱动系统。
Audi RS6 Quattro, which we usually call RS6, is a high-performance version in the A6 product line, and its positioning is higher than that of Audi S6. This is a sports oriented five door five seat station wagon developed and produced by Audi's Quattro GmbH.
The abbreviation for "RS" is taken from German: rennsport. "Motorsport" represents Audi's top performance level and is positioned on top of the "s" Audi enhanced performance model series. Like all Audi RS series, Audi RS6 uses the latest and most advanced engineering and technology, so it can be called a halo vehicle. It has the most powerful engine data of all Audi models, even surpassing the bigger Audi S8. In addition, like all RS models, Audi RS6 [1] uses Quattro four-wheel drive system produced by Torson.
提到旅行车,虽然SUV已经取代旅行车的功能,不过也因为SUV车型得火热让其变得更小众,那份别具风味的属性也更加强烈。而本期带来全新一代奥迪RS6的改装案例。
When it comes to station wagons, although SUVs have replaced station wagons, they have become less popular because of the popularity of SUVs, and their unique flavor is also stronger. This issue brings a new generation of Audi RS6 modification case.
