查看: 744|回复: 0
静若处子动若脱兔 奥迪Q5气动避震改装低趴姿态魅力四射
发表于 2021-6-3 13:43:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Audi Q5 pneumatic shock absorber refitted low lying posture charming
改装不分高低贵贱,改装不分车型,改装就是血液里涌动着机油般的冲动,时下正开始流行的气动避震,  AIRBFT空气避震的控制系统说它早就摸得精通了,下面这台奥迪Q5 自然是安装了AIRBFT空气避震的控制系统中毒的朋友来看看效果吧!
Refit regardless of high or low, refit regardless of model, refit is surging oil like impulse in the blood, now is beginning to popular pneumatic shock absorber, airbft air shock absorber control system said it has long been proficient, the following Audi Q5 is naturally installed with airbft air shock absorber control system, poisoned friends to see the effect!
多数人使用气压式避震器最主要的目的并非以舒适性为主,随时调整车身底盘的高低才是换装气压式避震器最主要的诉求。气压避震是用气囊来替代弹簧的减震作用,然后在使用控制系统给气囊充气,充气量愈多车身就上升愈高,反之则会让车身降低,所以气压避震主要的目的是控制高低,而避震功能还是以原本的弹簧、减震筒为主。气动避震器就是安装在汽车悬挂上的空气避震器,它利用橡胶气囊来代替原厂的弹簧,并通过控制器的控制来调节底盘的高度。这简单的一句话概括了气动避震系统的两大组成部分——一部分是悬挂,一部分是控制器。其中橡胶气囊避震器、气压控制系统、储气罐、电子控制系统、气泵、连接管路等必不可少的部件。
The main purpose of most people using pneumatic shock absorbers is not comfort. The main demand of replacing pneumatic shock absorbers is to adjust the height of the chassis at any time. Pneumatic shock absorption is to replace the shock absorption function of spring with air bag, and then inflate the air bag with the control system. The more the air is inflated, the higher the body will rise, otherwise it will make the body lower. Therefore, the main purpose of pneumatic shock absorption is to control the height, and the shock absorption function is mainly based on the original spring and shock absorber. Pneumatic shock absorber is an air shock absorber installed on the automobile suspension. It uses rubber air bag to replace the spring of the original factory, and adjusts the height of the chassis through the control of the controller. This simple sentence summarizes the two major components of the pneumatic shock absorber system -- one is the suspension, and the other is the controller. Among them, rubber airbag shock absorber, air pressure control system, air tank, electronic control system, air pump, connecting pipeline and other essential components.
