查看: 707|回复: 0
速腾GLI气动避震改装魅力出演引领低趴改装潮
发表于 2021-5-28 16:34:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Su Teng Gli's charm of pneumatic shock absorption modification leads the tide of low lying modification
速腾gli是德国大众汽车集团在中国的合资企业—一汽-大众汽车有限公司生产汽车品牌,起源于1984年的大众GLI是大众A级三厢轿车中的高性能车系。
新速腾GLI不仅仅是一部高性能的运动轿车,更是一件饱含激情的艺术品。新速腾GLI在延续速腾品牌一贯的卓越品质和精湛工艺的基础上,实现了质感、舒适与运动的完美平衡。
Sunteng Gli is a brand produced by FAW Volkswagen Co., Ltd., a joint venture of German Volkswagen Group in China. Originated in 1984, Volkswagen Gli is a high-performance car series of Volkswagen A-class three compartment cars.
The new super Gli is not only a high-performance sports car, but also a work of art full of passion. On the basis of the consistent excellent quality and exquisite craftsmanship of the brand, the new speedy Gli achieves the perfect balance of texture, comfort and movement.
速腾GLI虽然是一款性能车,不过低趴的贴地改装风格也能玩出不一样的味道,如果你还在犹豫自己的爱车是否能够驾驭得住 改装风格,那么 今天给大家分享的是速腾GLI演绎气动避震悬挂的低趴魅力,精彩出演自己人生剧情的重要一环。
Although the speedeng Gli is a performance car, the low lying refitting style can also play a different flavor. If you are still hesitating whether your car can control the refitting style, what I want to share with you today is the low lying charm of the pneumatic suspension performed by the speedeng Gli, which is an important part of your life story.
