查看: 755|回复: 0
ES300h传承经典之作改装气动避震年轻人的品质享受
发表于 2021-5-28 13:57:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Es300h inherits classic works and refits pneumatic shock absorber
雷克萨斯ES300h作为LEXUS雷克萨斯家族中享誉全球的经典车型,ES系列自问世以来便以优雅的设计和卓越的品质赢得了全球无数消费者的倾慕。此次推出的全新一代ES豪华轿车,采用了LEXUS雷克萨斯先进的设计理念与尖端科技,为C级豪华车市场开创了崭新豪华基准。2012年正值LEXUS雷克萨斯的“混合动力元年”,ES系列首次引入了油电混合动力车型ES 300h,将环保与豪华完美结合,为更多消费者带来超越期待的完美驾乘选择。
Lexus es300h is a world-famous classic model in Lexus family. Since its inception, ES series has won the admiration of numerous consumers around the world with its elegant design and excellent quality. This new generation of ES luxury car adopts the advanced design concept and cutting-edge technology of Lexus, which creates a new luxury benchmark for the C-class luxury car market. In 2012, Lexus was in the "first year of hybrid", the ES series introduced the oil electric hybrid es 300h for the first time, perfectly combining environmental protection with luxury, bringing more consumers a perfect driving choice beyond expectations.
在这个看颜值,拼个性的时代,一台再好的车子,没改装的话在街上也是毫不起眼,(超跑除外),雷克萨斯在我的眼中是一个运动感十足而又不失端庄 ,而雷克萨斯ES300更是将这些完美的体现出来!下面的这台改装AIRBFT气动避震雷克萨斯ES300,以最完美的低姿态展示在大家的眼前!加凸显出了高贵的气质和迸发位处的运动细胞!
In this age of beauty and personality, no matter how good a car is, it's unimportant on the street without modification (except super run). In my eyes, Lexus is a sporty and dignified car, and the Lexus ES300 is a perfect embodiment of these! The following modified airbft pneumatic shock absorber Lexus ES300 is displayed in the most perfect low profile in front of everyone's eyes! Add highlight the noble temperament and burst out at the position of the sports cell!
首先,在更换车辆避震系统前一定要先知道更换的避震器的功能,以及你改装的需要。当然避震器的主要构成是由四个避震弹簧以及四只避震筒组合而形成,弹簧最主要的功用是用来消除行经不平路面的震动,我想这谁都知道。但许多人会问四只避震筒在车辆行进中又可以起到什么样的作用?其实避震筒的真正用途用来抑制弹簧吸震後反弹时的震荡和吸收路面冲击的能量。假如你开过避震器坏掉的车,你就可以体会车子通过每一坑洞、起伏後馀波荡漾的弹跳,而避震器正是用来抑制这样的弹跳。没有避震器将无法控制弹簧的反弹,车子遇到崎岖路面时将会产生严重的弹跳,过弯时也会因为弹簧上下的震荡而造成轮胎抓地力和循迹性的丧失,所以避震筒对车辆的操控力还是起着至关重要的作用。
First of all, be sure to know the function of the replaced shock absorber and the need of your modification before replacing the vehicle's shock absorber system. Of course, the main structure of the shock absorber is composed of four shock absorbers and four shock absorbers. The main function of the spring is to eliminate the vibration of the uneven road. I think everyone knows that. But many people will ask what role can four shock absorbers play when the vehicle is moving? In fact, the real purpose of the shock absorber is to suppress the shock when the spring rebounds after the shock absorption and absorb the energy of road impact. If you've ever driven a car with a broken shock absorber, you can experience the bouncing of the car through every hole and after the ups and downs, and the shock absorber is used to suppress such bouncing. Without the shock absorber, the rebound of the spring can not be controlled. When the car encounters a rough road, it will have a serious bounce. When it turns, it will also cause the loss of tire grip and tracking due to the vibration of the spring up and down. Therefore, the shock absorber still plays a vital role in the control of the vehicle.
