查看: 618|回复: 0
坦途改装拖挂房车专用气囊超强承载旅行专属专用AIRBFT气动避震套件
发表于 2021-5-27 15:33:09 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Tantu refitted Trailer special air bag super load travel special airbft pneumatic shock absorber Kit
丰田坦途(丰田Tundra)是一款日本丰田公司生产的美版的大皮卡,其大小可以和悍马不差上下。这款车主要在北美销售,国内进口少量。
很适合长途旅行的代步工具,它受到一度追捧的原因在于它的多功能性--集合了SUV的越野性能、卡车的载货能力、以及轿车的舒适性。
下面这辆坦途改装AIRBFT气动避震,一万公里路试凯旋归来,无论是高原还是冰川,无论是戈壁还是沙漠都无法阻挡,畅通无阻。
Toyota tundra is a large pickup truck made by Toyota in Japan, which is the same size as Hummer. The car is mainly sold in North America, with a small amount of domestic imports.
It is very suitable for long-distance travel. The reason why it was once popular is its versatility, which combines the off-road performance of SUV, the carrying capacity of truck and the comfort of car.
The following flat road is refitted with airbft pneumatic shock absorber. After a 10000 kilometer road test, the car returns successfully. No matter it's plateau or glacier, no matter it's Gobi or desert, it's unobstructed.
首先,在更换车辆避震系统前一定要先知道更换的避震器的功能,以及你改装的需要。当然避震器的主要构成是由四个避震弹簧以及四只避震筒组合而形成,弹簧最主要的功用是用来消除行经不平路面的震动,我想这谁都知道。但许多人会问四只避震筒在车辆行进中又可以起到什么样的作用?其实避震筒的真正用途用来抑制弹簧吸震後反弹时的震荡和吸收路面冲击的能量。假如你开过避震器坏掉的车,你就可以体会车子通过每一坑洞、起伏後馀波荡漾的弹跳,而避震器正是用来抑制这样的弹跳。没有避震器将无法控制弹簧的反弹,车子遇到崎岖路面时将会产生严重的弹跳,过弯时也会因为弹簧上下的震荡而造成轮胎抓地力和循迹性的丧失,所以避震筒对车辆的操控力还是起着至关重要的作用。
First of all, be sure to know the function of the replaced shock absorber and the need of your modification before replacing the vehicle's shock absorber system. Of course, the main structure of the shock absorber is composed of four shock absorbers and four shock absorbers. The main function of the spring is to eliminate the vibration of the uneven road. I think everyone knows that. But many people will ask what role can four shock absorbers play when the vehicle is moving? In fact, the real purpose of the shock absorber is to suppress the shock when the spring rebounds after the shock absorption and absorb the energy of road impact. If you've ever driven a car with a broken shock absorber, you can experience the bouncing of the car through every hole and after the ups and downs, and the shock absorber is used to suppress such bouncing. Without the shock absorber, the rebound of the spring can not be controlled. When the car encounters a rough road, it will have a serious bounce. When it turns, it will also cause the loss of tire grip and tracking due to the vibration of the spring up and down. Therefore, the shock absorber still plays a vital role in the control of the vehicle.
Refitting pneumatic shock absorber: pneumatic shock absorber is the most popular refitting project recently. Its simple refitting steps (you can also install it at home) and the feature of no harm to the refitted parts of the car body satisfy the car owners who want to refit but are afraid of hurting their car. Its simple and flexible handling and comfort are still the projects that the car owners are happy with, The above advantages make the pneumatic shock absorber more convenient
Operation: airbft pneumatic shock absorber has four-wheel independent operation (four wheels can control the height, soft and hard separately), three section memory function (can remember the height of three cars, for example: 1 key can be set to the lowest prone state, 2 key can be set to the height of the original car or the most comfortable height for the driver, 3 keys can be set to the highest height. The highest height of the general vehicle is higher than that of the original vehicle) wireless remote control (pneumatic control can be controlled remotely)
