查看: 618|回复: 0
童心未泯VW Beetle改装气动避震最美低姿态萌萌哒
发表于 2021-5-27 14:31:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
VW Beetle refitted pneumatic shock absorber, the most beautiful low profile cute
大众甲壳虫(Volkswagen Beetle)正式名称为大众1型(Volkswagen Type 1),是由大众汽车(香港译福士车厂)在1938年至2003年间生产的一款紧凑型轿车。1998年,在最初的甲壳虫下线许多年以后,大众汽车正式推出了外形与原先非常相似的新甲壳虫(以大众高尔夫(Golf)为平台),而甲壳虫则在墨西哥和其他少数一些国家一直生产到2003年。在评选最具世界影响力的“20世纪汽车”的国际投票中,甲壳虫排名第四,仅次于福特T型车、迷你和雪铁龙DS。
Volkswagen Beetle, officially known as Volkswagen type 1, is a compact car produced by Volkswagen from 1938 to 2003. In 1998, many years after the initial beetle was launched, Volkswagen officially launched a new beetle with a very similar appearance (based on the Volkswagen Golf platform), while the beetle was produced in Mexico and a few other countries until 2003. In the international vote for the most influential "20th century car" in the world, the beetle ranked fourth, after the Ford T, mini and Citroen DS.
大众甲壳虫已经有多年的历史了, 发展到今天的甲壳虫外观上比以前更加的接近昆虫的形状, 很受玩家的欢迎,这款车之所以能够在全球得到不错的推广,完全是因为能够迷倒万千少女,活泼可爱且萌萌的会让无数的少女痴迷尖叫!今天要谈论的这辆甲壳虫是改装了气动避震低趴风格的,  完美形态更加接近自然!
The Volkswagen Beetle has a history of many years. Today's beetle is more similar to the shape of insects than before, and is very popular with players. The reason why this car can be well promoted in the world is that it can charm thousands of girls, and the lively, lovable and cute will make countless girls crazy and scream! The beetle we are going to talk about today is refitted with pneumatic shock absorber and low prone style. The perfect shape is closer to nature!
3: Responsible installation and modification shop, handling every detail, checking before delivery, air leakage, loose abnormal noise, damping height!
4: Before refitting, what you need, how you want to play, whether you want the effect after installation, and whether you have the convenience in the process of use
