查看: 573|回复: 0
英菲尼迪G37改装AIRBFT气动避震跑高速安全吗
发表于 2021-5-23 16:51:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Is it safe for Infiniti G37 to refit airbft pneumatic shock absorber to run at high speed
英菲尼迪G37,标准引擎 VQ37HR 3.7升(3696cc)V6发动机/双顶置凸轮轴(DOHC),每缸4气门/连续可变气门正时控制系统(CVTCS)/可变气门升程技术(VVEL) 标准变速器 手自一体 7档 标准排量 3696 cc
Infiniti G37, standard engine vq37hr 3.7L (3696cc), V6 engine / DOHC, 4 valves per cylinder / cvtcs / VVEL standard transmission, 7-gear, standard displacement 3696cc
生活中随处可见的低趴姿态同样让很多行外人产生了疑惑…车子放的这么低,跑起来就方面吗?改成这样还敢跑吗!它们不仅可以跑,而且跑的可以很精彩!不然怎么能叫“贴地飞行”呢!
The low posture that can be seen everywhere in life also makes many laymen wonder... Is it easy to run when the car is so low? Do you dare to run like this! They can not only run, but also run wonderfully! Otherwise, how can it be called "flying close to the ground"!
Refitting pneumatic shock absorber: pneumatic shock absorber is the most popular refitting project recently. Its simple refitting steps (you can also install it at home) and the feature of no harm to the refitted parts of the car body satisfy the car owners who want to refit but are afraid of hurting their car. Its simple and flexible handling and comfort are still the projects that the car owners are happy with, The above advantages make the pneumatic shock absorber more convenient
Operation: airbft pneumatic shock absorber has four-wheel independent operation (four wheels can control the height, soft and hard separately), three section memory function (can remember the height of three cars, for example: 1 key can be set to the lowest prone state, 2 key can be set to the height of the original car or the most comfortable height for the driver, 3 keys can be set to the highest height. The highest height of the general vehicle is higher than that of the original vehicle) wireless remote control (pneumatic control can be controlled remotely)
space: the pneumatic control system is generally placed in the trunk, which takes up the same space as the spare tire of a car. It can be hidden in the place of the spare tire or placed in the corner of the trunk. It can be protected by custom-made wooden cases, which can save space safely and put East and West on it.
