查看: 567|回复: 0
十代思域分享介绍汽车底盘改装气动避震是什么意思
发表于 2021-5-20 16:50:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ten generations of civic share and introduce the meaning of automobile chassis refitting pneumatic shock absorber
2016年4月12日,东风本田正式公布了新一代思域的售价,新思域是本田第十代Civic的国产版车型,  全新思域基本延续了海外车型的造型设计,装配全LED大灯。新车车身侧面的设计要比前脸更加大胆,C柱的平缓过渡类似于一款Coupe车型,采用了“括号式”LED尾灯,且灯组呈现出飞镖形状。此外,全系车型均装备有自动感应雨量雨刷、带加热功能的电动后视镜。
On April 12, 2016, Dongfeng Honda officially announced the price of the new generation Civic. The new Civic is the domestic version of Honda's 10th generation Civic. The new civic basically continues the modeling design of overseas models and is equipped with all LED headlights. The side design of the new car is bolder than that of the front face. The smooth transition of the C-pillar is similar to a coupe model, which adopts "bracket" LED tail lights, and the light group presents a dart shape. In addition, all models are equipped with automatic rain sensing wiper and electric rearview mirror with heating function.
The refitting of automobile chassis has a large proportion in the refitting industry. The chassis system of the original car can't meet the needs of the players now. Refitting is imperative. In recent years, the refitting of tooth twisting shock absorber is the mainstream choice of the players. It not only reduces the body, increases the aesthetic feeling, but also improves the vehicle control. However, the hardness is not acceptable to ordinary people, and the bad road makes tooth twisting party suffer, Now the emergence of pneumatic shock absorbers, so that the players to play twisted teeth to see a new dawn. The low lying effect when parking, and the car body can be raised when driving. It's really cool to lift at will. If the adjustment is good, the comfort is a little better than the tooth twisting. Now it has become a trend of chassis suspension modification. If the stability and comfort are better, it will become the most popular modification project in the future!
