查看: 636|回复: 0
“凌风渡越”凌渡展示气动避震和空气悬挂的低趴姿态改装原理
发表于 2021-5-20 15:37:49 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Lingfengduyue" lingdu demonstrates the principle of low prone posture modification of pneumatic shock absorber and air suspension
凌渡(Lamando)是上汽大众2014年8月在成都车展推出的一款紧凑型新车。
上汽大众将凌渡定义为“首款宽体轿跑车”,其基于MQB平台打造,搭载EA888 TSI、EA211 TSI发动机,采用干式7速双离合变速器。
主打高端,属运动型紧凑车,定位于朗逸和帕萨特之间。
Lamando is a compact new car launched by SAIC Volkswagen at Chengdu auto show in August 2014.
SAIC Volkswagen defines lingdu as "the first wide bodied coupe", which is built on MQB platform, equipped with EA888 TSI and ea211 TSI engines, and adopts dry 7-speed dual clutch transmission.
Focusing on high-end, it is a compact sports car, positioned between Lavigne and Passat.
我经常看一些改装案例,很多车辆都会让人深度着迷,不同于大批量“同化”的家用车,有些人更希望自己的爱车成为最稀有最个性的一辆,当然改装文化的不同也受因素的影响,但是不管怎么改装,最棒的还是空气悬挂气动避震的改装,我们都是希望自己的座驾在吸引更多路人目光的同时,也能和大家分享改装的魅力!
I often see some refitting cases. Many vehicles are deeply fascinating. Unlike a large number of "assimilated" family cars, some people prefer their car to be the rarest and most personalized one. Of course, the refitting culture is also affected by factors. However refitting, the best one is the refitting of air suspension and pneumatic shock absorbers, We all hope that our car can attract more passers-by's attention and share the charm of refitting with you!
气动避震器扣弹性橡胶气囊减震器、气压控制系统、后备厢储气罐、电子控制系统等等。
通过气压来控制改变车子的高低,正所谓一低遮三丑,终极玩家最喜欢的就是可以随心所欲操控车身高度,非常有成就感。
Pneumatic shock absorber, elastic rubber airbag shock absorber, air pressure control system, rear compartment air tank, electronic control system, etc.
The air pressure is used to control and change the height of the car. It's the so-called "one low cover three ugly". The ultimate player's favorite is that he can control the height of the car body at will, which is very successful.
Pneumatic shock absorber, as the name suggests, is a kind of shock absorber that controls the height of the car body through air pressure. The working principle of pneumatic shock absorption is to change the height of the car by controlling the air pressure, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system. Many riders are limited to the mechanical adjustment and road condition of tooth twisting shock absorbers, so they can't make their car in perfect posture anytime and anywhere. So pneumatic shock absorbers belong to a blessing. In fact, pneumatic shock absorbers are not only used in refitted cars, but also in many original models, such as jeep Grand Cherokee, Land Rover Discovery, etc, Even a lot of supercars come with pneumatic shock absorbers.
