查看: 530|回复: 0
丰田向您展示气动避震HellaFlush风格国际化的改装车的外观潮流
发表于 2021-5-20 14:38:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyota shows you the appearance trend of international refitted cars with pneumatic shock absorption hellaflush style
丰田汽车公司(日文汉字转简体:トヨタ自动车株式会社,英文:Toyota Motor Corporation ),是一家同时在东京证交所(TYO)   、名古屋证交所(NAG) 、纽约证交所(NYSE) 和伦敦证交所(LSE) 上市的日本跨国汽车制造商。总部位于日本爱知县丰田市和东京都文京区。创始人为丰田喜一郎(1894-1952),  现任社长丰田章男(丰田喜一郎之孙)。
Toyota Motor Corporation is a Japanese multinational automobile manufacturer listed on the Tokyo Stock Exchange (tyo), Nagoya Stock Exchange (NAG), New York Stock Exchange (NYSE) and London Stock Exchange (LSE). Its headquarters are located in Toyoda, Aichi Prefecture, Japan, and Tokyo, Tokyo. The founder is Yoshiro Toyoda (1894-1952), and the current president is Zhangnan Toyoda (the grandson of Yoshiro Toyoda).
随着时代的进步,人们对车不仅仅是代步工具,更多的是个性的姿态, 让很多的爱车之士垂涎三尺,下面请欣赏丰田改装气动避震的低趴姿态,加上一套完美的适合自己风格的大尺寸轮毂, 完美轻松玩转Hellaflush风格
With the progress of the times, the car is not only a means of transportation, but also a personal gesture, which makes many car lovers salivate. Now, please enjoy the low prone posture of Toyota modified pneumatic shock absorbers, plus a perfect set of large-size wheels suitable for your own style, which makes you play hellaflush style perfectly and easily
HellaFlush已经成为了一个国际化的改装车的外观潮流,随着国内改装车的发展与进步,越来越多的被大众所接受,HF范儿也成为了一种品位的象征轮毂在正确的Offset(轮毂负值)下,和车身齐平的效果。同时不可或缺的是,你必须尽可能降低你的车身才能称为HellaFlush,这里说的降低车身到多低是没有确切标准的,但是有个基本规则就是绝对不能在轮胎和叶子板中间有空间(Wheel Gap)。 如果你不把你的车降到特别特别低,你只是Flush。
HellaFlush的主要特征:
Hellaflush has become an international appearance trend of refitted vehicles. With the development and progress of domestic refitted vehicles, more and more of them are accepted by the public. HF model has also become a symbol of taste. Under the correct offset (wheel hub negative value), the wheel hub has the same effect as the car body. At the same time, it is indispensable that you lower your car body as much as possible in order to be called hellaflush. There is no exact standard for how low the car body is. However, there is a basic rule that there must be no space between the tire and the vane. If you don't lower your car very, very low, you just flush.
The main features of hellaflush are as follows:
1. The central idea of hellaflush is offset is everything. The wheel hub uses an offset value that is more stretched than the normal value, so that the wheel hub is beyond the coverage of the body fender.
2. The distance between the wheel eyebrow and the wheel hub should be as small as possible. To complete this task, the car body should be lowered to a height that does not conform to the daily use, so that some HF style cars can't drive at all, so they have to use a trailer to pull the orz. As for how to lower the car body, there is no standard. Pneumatic shock absorbers, twisted teeth shock absorbers, short springs, or even modified sheep horns, you can do anything to achieve your goal.
3. As a result of the first two points, if the tire wants not to be rubbed and burst by the fender, it must use a specification narrower than the width of the wheel hub, so that the edge of the tire can be retracted so that it can be completely hidden in the fender. Of course, the fender can also be rolled in or expanded to a certain extent according to the protruding degree of the wheel hub.
4. If you want to have more attitude than attitude, you can't take the normal road for the inclination value of the tire. Take off at minus 2 degrees (that is, the upper part of the track is narrow and the lower part is wide). The method can be to adjust the inclination rocker arm, gasket and change the sheep's horn. In a word, we can't see eye to eye with normal people.
5. Tire stretch refers to the effect of the narrow tire installed on the ultra wide wheel hub. It's not easy to achieve this effect. Choosing a variety of tires should be strictly calculated according to the width of the wheel hub. Because, too wide hub with a narrow tire, when the tire inflation may dislocation, so can let the tire according to the correct position taut on the hub depends on the technician's modification level.
