查看: 545|回复: 0
别克新君越AIRBFT四轮独立控制系统避震套装改装怎么样
发表于 2021-5-20 14:13:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
How about Buick new LaCrosse airbft four wheel independent control system shock absorption suit modification
君越(Lacrosse)是上汽 通用在2006年2月22日推出的一款全新中高档轿车,“君”代表高品位、高档次的形象,“越”具有“突破、超越”的寓意;2020年7月27日,上汽通用汽车别克品牌宣布2021款君越家族上新,共推出四款车型,售价21.98万元-28.98万元。其中,新增一款552T豪华型携全新动力总成“入列”,新车搭载通用汽车1.5T SIDI直喷涡轮增压发动机与9速HYDRA-MATIC智能变速箱高效驱动组合,为消费者带来更加丰富的中高级车选择。此外,2021款君越家族全系搭载升级迭代的别克eConnect智能互联科技,以动感优雅的设计语言和“标准之上”的越级品质,为消费者打造智能、安全、舒适、愉悦的驾乘体验。
Lacrosse is a brand-new medium and high-grade car launched by SAIC GM on February 22, 2006. "Jun" stands for the image of high-grade and high-grade, "Yue" has the meaning of "breakthrough and Transcendence"; On July 27, 2020, SAIC General Motors Buick announced that 2021 Lacrosse family models will be launched, with a total of four models sold for 219800-289800 yuan. Among them, a new 552t luxury vehicle with a new powertrain is added. The new vehicle is equipped with GM's 1.5T Sidi direct injection turbocharged engine and 9-speed Hydra-matic intelligent transmission, which provides consumers with more choices of medium and advanced cars. In addition, the 2021 Lacrosse family is equipped with the upgraded and iterative Buick econnect intelligent Internet technology to create an intelligent, safe, comfortable and pleasant driving experience for consumers with dynamic and elegant design language and "above standard" leapfrog quality.
日常生活中,越来越多的人喜欢改装自己的爱车,有的喜欢改音响,有的喜欢改车灯,还有的喜欢改装气动避震等。近日,与一位别克君越车友沟通了很久,了解到选择改装气动避震的原因主要有两方面:一方面是希望通过改装气动避震来提升车子的舒适性和操控性;另一方面是为了实现自己追求低趴的梦想。今天就用实例为大家分享一下气动避震的改装。
In daily life, more and more people like to modify their car, some like to change the sound, some like to change the lights, and some like to modify the pneumatic shock absorber. Recently, I communicated with a Buick LaCrosse driver for a long time and learned that there are two main reasons for choosing to refit pneumatic shock absorbers: on the one hand, I hope to improve the comfort and handling of the car by refitting pneumatic shock absorbers; On the other hand, in order to realize their dream of low lying. Today, I will share the modification of pneumatic shock absorber with an example.
话说这是个什么东西呢?它其实是一套可以控制气压,改变车身高低的装置,与传说中的主动车身控制系统(ABC)类似,不过它的工作介质是气体,一般来说就是下图所示的这么一套家伙事,其中包括弹性橡胶气囊减震器,气压控制系统、后备箱储气罐,及电子控制系统等,它其实和空气减震的原理与常见减震器螺旋弹簧+减震筒形式,原理十分类似,只不过,通过改变气室体积(上下方向),来调整车身离地距离并一定程度改变软硬特性,另外减震筒部分则可以由电机改变通气孔尺寸,从而调节减震器的衰减力,因此空气减震器往往,能提供更好的性能表现,嗯!就是这么自信!
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank, electronic control system, etc, In fact, the principle of the air shock absorber is very similar to that of the common shock absorber coil spring + shock absorber cylinder, except that the distance between the car body and the ground can be adjusted by changing the volume of the air chamber (up and down direction), and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the air vent can be changed by the motor in the shock absorber cylinder part, so as to adjust the damping force of the shock absorber, Can provide better performance, eh! So confident!
Pneumatic shock absorber is a more precise part, which is different from the original shock absorber. There is an elastic rubber air bag on the pneumatic shock absorber. The working principle of the elastic rubber air bag is to fill the closed pressure cylinder with inert gas or oil gas mixture, so that the pressure in the cavity is several times or dozens of times higher than the atmospheric pressure, The movement of the piston rod is realized by the pressure difference caused by the cross-sectional area of the piston rod being smaller than that of the piston. Pneumatic shock absorbers are not suitable for driving on various complicated road conditions. Driving on bumpy roads for a long time will lead to chronic air leakage, unstable air pressure, temperature rise in the air tank, and eventually lose the accuracy of pneumatic adjustment.
