查看: 579|回复: 0
Q50为您展示AIRBFT气动避震改装系统配置全部清单
发表于 2021-5-20 13:52:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Q50 shows you the complete list of air-driven shock avoidance modification system configuration
英菲尼迪Q50是英菲尼迪在北美市场采用的新的命名方式,在2013年1月15日北美车展上发布的一款新车,该车其实就是换代的G系列。
Infiniti Q50 is a new naming method adopted by Infiniti in the North American market. It is a new car released at the North American auto show on January 15, 2013. In fact, it is a new generation of G series.
英菲尼迪Q50依然是一种具有完美风格体现的轿跑车型,改装低姿态效果完美!下面欣赏这辆Q50改装AIRBFT气动避震悬挂更多的改装资讯
Infiniti Q50 is still a car model with perfect style, and the effect of low-profile refitting is perfect! Now enjoy the Q50 modified airbft pneumatic suspension, more modification information
AIRBFT控制系统
        AIRBFT气动避震套件清单:
AIRBFT ECU阀体*1个
AIRBFT 液晶遥控器*1个
AIRBFT 遥控器线束*1组
AIRBFT 静音打气泵*1台(V360)
AIRBFT 自动滤水器*1个
AIRBFT 铝合金无缝气瓶*1个(3加仑)
AIRBFT 全车高压气管*1盘(20米)
AIRBFT 整车接头*1套
AIRBFT 专用电源线*1根
AIRBFT避震桶身*1套(台湾正品)
        控制系统版本
Airbft control system
Airbft pneumatic shock absorber kit list:
Airbft ECU valve body * 1
Airbft LCD remote controller * 1
Airbft remote control harness * 1 set
Airbft silent air pump * 1 set (V360)
Airbft automatic water filter * 1
Airbft aluminum alloy seamless cylinder * 1 (3 Gal)
Airbft high pressure air pipe * 1 disc (20m)
Airbft vehicle connector * 1 set
Airbft dedicated power line * 1
Airbft shock absorber barrel * 1 set (Taiwan genuine)
Control system version
2022款AIRBF气压记忆系统功能介绍:
1:四轮独立升降、前后独立升降、一键降低;
2:气罐压力可调,打气泵工作开关
3:三段气压记忆,手机APP遥控
4:点火自动升高,熄火自动低趴,支持中,英文等多种语言:
5:遥控面板自带液晶显示屏,主要显示4轮气包气压值和气瓶气压值
6:可升级高度传感器记忆,记忆更加精准
2022款高度记忆,可以相互切换记忆模式,使用更加简单方便,功能如下:新款采用8连阀设计,升降速度比上一款的六连阀更快,苹果手机APP遥控及升级语音控制,可通过语音指令调节车身高度,更加智能化。三段记忆液晶遥控手柄,受到市场玩家的喜爱保持原有外观设计。四轮独立升级,前后独立升降四轮整体升降。气罐压力值可调,空气压缩机开关功能。三段记忆高度功能,着车自动升高,熄火自动低趴。多种语言选项和背光高度调节。全新配套静音打气泵,无焊接旋压一体防爆高压气罐,台湾32段阻尼可调减震器,品质全新升级,更优质的产品和服务为广大车友保驾护航。
Function introduction of 2022 air pressure memory system:
1: Four wheel independent lifting, front and back independent lifting, one key lowering;
2: The pressure of the air tank is adjustable, and the working switch of the air pump is on
3: Three stage air pressure memory, mobile app remote control
4: Automatic ignition up, automatic flameout low prone, support Chinese, English and other languages:
5: The remote control panel is equipped with liquid crystal display screen, which mainly displays the air pressure value of 4-wheel air bag and gas cylinder
6: Can upgrade height sensor memory, memory more accurate
2022 height memory, can switch memory mode, use more simple and convenient, the function is as follows: the new model adopts 8-connected valve design, the lifting speed is faster than the previous six connected valve, Apple App remote control and upgrade voice control, can adjust the body height through voice command, more intelligent. Three memory LCD remote control handle, loved by market players, keep the original appearance design. Four independent upgrade, front and rear independent lifting, four overall lifting. The pressure value of the air tank is adjustable, and the air compressor has on-off function. Three section memory height function, the car will automatically rise when the car is on, and the car will automatically lie down when the car is off. Multiple language options and backlight height adjustment. New matching silent pump, no welding spinning integrated explosion-proof high-pressure gas tank, Taiwan 32 section damping adjustable shock absorber, new quality upgrade, better products and services for the majority of riders escort.
