查看: 573|回复: 0
丰田锐志改装AIRBFT气动避震步骤分享
发表于 2021-5-19 16:43:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Steps of Fengtian Ruizhi refitting airbft pneumatic shock absorber
在日本MARK X是一款运动型车,而国产后,MARK X被赋予了一个响亮的中文名――锐志(Reiz),同时在德语中意为“魅力”的“Reiz”也出现在车的尾部。这款车的定位区间(功能的对手/非单纯价格)非常的大,从十几万上下的宝来,到Mazda6、天籁、奥迪A4直到宝马530i,只要和运动沾边的车,都可以看作它的对手。
In Japan, mark X is a sports car. After being made in China, mark X has been given a loud Chinese name - Reiz. At the same time, Reiz, which means "charm" in German, also appears in the rear of the car. The positioning range of this car is very large, from Bora, Mazda6, Teana, Audi A4 to BMW 530i. As long as the car is related to sports, it can be regarded as its opponent.
气动避震改装"低趴范儿"在全球已经成为一种流行趋势, 深受广大改装车迷追捧,它不仅能在视觉上给人一种强烈的冲击感,而且也能充分的展现出个性车主的独特品味。但是改装也是真的不容易,你得同时是修理工,电工,木工,设计师,机械师…………
下面是丰田锐志改装vvX AIRBFT气动避震的案例和步骤,改装师傅通过自己的双手打造出了一台低趴大王!
Pneumatic shock absorber refitting "low lying style" has become a popular trend in the world, which is sought after by the majority of refitting fans. It can not only give people a strong sense of visual impact, but also fully show the unique taste of individual car owners. But it's not easy to refit. You have to be a repairman, electrician, carpenter, designer, mechanic at the same time
The following is the case and steps of Toyoda Ruizhi's modification of vvx airbft pneumatic shock absorber. The modification master has created a low lying king with his own hands!
下面就来一步步的分解一下:
Installation of pneumatic shock absorber is roughly divided into four parts, that is, the installation of pneumatic shock absorber, pipeline laying, line positioning, and control system installation!
First of all, the installation of pneumatic shock absorbers. The installation of pneumatic shock absorbers is actually the same as the replacement of ordinary twisted tooth shock absorbers. Shock absorbers are all installed in the original vehicle. What we need to pay attention to is to calculate the maximum and minimum range required by the owner according to the shock absorbers' travel, adjust the height of the throttle shock absorbers, and reserve the position of the air pipes, Generally, the air pipe is on the inside, and the rest is according to the normal shock absorption installation steps.
The laying of pipelines is a time-consuming work. The methods and ideas of every installation master are different. However, one principle to follow is to avoid the places where there may be dead bends or where the air pipe may be pressed or ground by the vehicle while driving, and to stay away from the exhaust, because the material of the air pipe is mostly high temperature, The best way is to follow the oil pipe.
It's very troublesome to move the lines along with the electrical circuits in the car. It's better not to cut off the main power line if you need to disassemble many interior parts. In addition, if there are other electrical equipment in the car, you must not share the power line to prevent mutual interference.
The installation of control system, airbft pneumatic shock absorption control system is quite simple control system, but want to perfect the installation still need to have some experience, there are a lot of details need to pay attention to, especially each joint and gas pipe and gas hole screw tooth connection, should be carefully installed, gas hole and joint screw tooth connection must be sealed, It should be that if there is air leakage, it is very troublesome to check and test again. Try to do it in one step.
