查看: 533|回复: 0
高尔夫6改装气动避震HellaFlush风格焕发世界各地青年人的激情
发表于 2021-5-19 16:05:49 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
高尔夫6改装气动避震焕发世界各地青年人的激情
Golf 6 modified pneumatic shock absorber hellaflush style radiates the passion of young people all over the world
高尔夫6(高尔夫第六代,包含GTI) 第6代高尔夫,应该算是大众汽车国产车型的重中之重了,众所周知的车子,因为很大的改装空间,也有很多人来对它进行大刀阔斧的改装,也有很多车友,拿它来当做是买菜车,简单的代步工具,高6,在市场的占有率是相当的大! 下面将要介绍的这台来自高尔夫6,通过改装气动避震和轮毂,让自己焕发出不一样的光彩!
Golf 6 (the sixth generation of golf, including GTI) the sixth generation of golf should be regarded as the top priority of Volkswagen's domestic models. As we all know, because of the large space for modification, there are many people to make drastic modifications to it, and there are many riders who use it as a shopping cart, a simple means of transportation, high 6, In the market share is quite large! The following will be introduced from the golf 6, through the modification of pneumatic shock absorber and wheel hub, let yourself glow a different luster!
正所谓一低遮百丑,这几年HF改装火遍大街小巷,气动减震也是一夜变身改装界网红,HellaFlush已经成为了一个国际化的改装车的外观潮流,随着国内改装车的发展与进步,越来越多的被大众所接受,HF范儿也成为了一种品位的象征
Just as the so-called "one low cover one hundred ugly", in recent years, HF refitting has become popular all over the streets, and pneumatic shock absorption has become a popular refitting industry overnight. Hellaflush has become an international appearance trend of refitted cars. With the development and progress of domestic refitted cars, more and more people accept HF retrofitting, and HF model has become a symbol of taste
HellaFlush的主要特征:
The main features of hellaflush are as follows:
1. The central idea of hellaflush is offset is everything. The wheel hub uses an offset value that is more stretched than the normal value, so that the wheel hub is beyond the coverage of the body fender.
2. The distance between the wheel eyebrow and the wheel hub should be as small as possible. To complete this task, the car body should be lowered to a height that does not conform to the daily use, so that some HF style cars can't drive at all, so they have to use a trailer to pull the orz. As for how to lower the car body, there is no standard. Pneumatic shock absorbers, twisted teeth shock absorbers, short springs, or even modified sheep horns, you can do anything to achieve your goal.
3. As a result of the first two points, if the tire wants not to be rubbed and burst by the fender, it must use a specification narrower than the width of the wheel hub, so that the edge of the tire can be retracted so that it can be completely hidden in the fender. Of course, the fender can also be rolled in or expanded to a certain extent according to the protruding degree of the wheel hub.
4. If you want to have more attitude than attitude, you can't take the normal road for the inclination value of the tire. Take off at minus 2 degrees (that is, the upper part of the track is narrow and the lower part is wide). The method can be to adjust the inclination rocker arm, gasket and change the sheep's horn. In a word, we can't see eye to eye with normal people.
5. Tire stretch refers to the effect of the narrow tire installed on the ultra wide wheel hub. It's not easy to achieve this effect. Choosing a variety of tires should be strictly calculated according to the width of the wheel hub. Because, too wide hub with a narrow tire, when the tire inflation may dislocation, so can let the tire according to the correct position taut on the hub depends on the technician's modification level.
