查看: 494|回复: 0
Lexus改装气动避震上演极致的低趴诱惑!
发表于 2021-5-19 14:48:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Lexus modified pneumatic shock absorbers perform the ultimate low lying temptation!
雷克萨斯(英语:Lexus;日语:レクサス),创立于1983年,是日本丰田集团旗下全球著名豪华汽车品牌。该品牌仅用了十几年的时间,销量在北美地区便超过了奔驰、宝马。
As you know, lexus; Chairman of the gonads. There is nothing that seems consistent with my worlds.
1999年起,雷克萨斯品牌连续11年位居美国豪华汽车销量第一的宝座。2005年,雷克萨斯成功打入日本本土市场,也因此成为在全球均有销售的高级轿车品牌。初时雷克萨斯在美国国内以“热切追求完美”(The Passionate Pursuit of Perfection)作为宣传口号,后来以“追求完美”(The Pursuit of Perfection)作为在全球国家和地区的行销格言,直到2013年,其宣传口号改为Amazing in Motion。
In 1999, keisuke, as you know is the tile Dynasty I was captured by a monologue of a hundredth century native land heitsu kishimei. In 2005, the thunderbolt, thus you know, was a successful percussion day and the city of mainland hama, with the land style matching the clothes with an additional galactic style. 'first responder, as you know, has been economic' (the passion response response of perfection) in the province uploading issue, the epicenter 'completed' (the passion response of perfection) in Japanese script, the International Grand National Union of kamikaze National Grand Prix d'amichi, kamikazuo '(the pursuit of perfection), the unhealthy comment, and the international uploading issue break in motion in 2013.
车子买来一次又一次的让它改变,变得与众不同,更具魅力,一般我们称他们为发烧车友,真的是这样吗? 不否认有那么一部分人确实是看到别人的车子一时冲动要玩改装,但还是有很多人是真心喜欢改装,喜欢折腾自己的车子,让他们与众不同,魅力无限!今天我们来欣赏这辆雷克萨斯改装气动避震的低趴魅力!这个姿态绝对不是一时冲动,就算当时是现在也会深深的去体会这份美。
The car has been bought again and again to make it different and more attractive. Generally, we call them feverish riders. Is that true? It is undeniable that some people do want to refit their cars on the spur of the moment when they see other people's cars, but there are still many people who really like refitting and tossing their own cars to make them different and charming! Today, we'll enjoy the low lying charm of this Lexus modified pneumatic shock absorber! This gesture is absolutely not impulsive, even if it was now will deeply experience the beauty.
气动避震的组成部分为控制系统和气动避震桶身两大类!
The components of the pneumatic shock absorber are control system and pneumatic shock barrel body!
Three section memory function: the owner can set three different height modes, i.e. high position, normal and low level, and push the key 123 to rise to or lower to the height suitable for the current road condition. At high speed, it can be lowered to the low level of 1st gear to reduce the center of gravity to enhance the stability and reduce wind resistance of the car, and to some extent save fuel, Cities or villages can be raised to the normal height of 2 to cope with most of the road conditions. If there is very poor road conditions, the car can be upgraded to third gear to improve the passing ability. It can be raised from the lowest to the highest level of about 12 cm! 3 different heights of gear can be quickly switched at any time!
Intelligent air replenishment and intelligent adjustment of car level: in fact, the functions of these two functions are probably the same. For example, when the car body is originally horizontal, a fat man sits in the rear seat, the height of the rear side will be reduced. At this time, the computer will detect the height change of the rear side and respond in less than a second, The two airbags in the back inflate to keep the body level!
The ignition will automatically rise to the set position height: such a function is that no matter what height you park, for example, the lowest or the highest, when you stop, get off and drive again, the system will automatically raise the car to the second gear position, that is, the normal car height! This has both advantages and disadvantages. For example, the road condition is very bad. There is no suitable parking space. When you park, you stop at the highest position. When you drive again, the system will automatically reduce. If you just park on a very high rural cement deceleration belt, it is very likely or direct bottoming! The advantage is that in a normal parking lot, the car stops to the lowest level. When you drive again, the train will automatically rise to the normal driving height at one o'clock. Think about how high the driving height is
One key to the lowest: a key, you can reduce the car to the lowest state! On the control panel, there is a one button to lower. Long press for 3 seconds, and the whole car will be in the lowest state! Why three seconds? Because this is to prevent misoperation. If your car is running, it's a terrible thing if a child or a special case accidentally touches the button with one button lowered. This design can completely avoid this situation. It doesn't matter if you accidentally touch all the buttons, as long as you don't press them for a long time!
