查看: 567|回复: 0
本田奥德赛改装气动避震悬挂姿态变身低趴一族
发表于 2021-5-17 14:52:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Honda Odyssey refits pneumatic suspension posture into low lying family
奥德赛是本田公司推出的一款车,于2007年1月在全国上市。配备了卫星导航系统,拥有8英寸的大显示屏和声音引导功能,使用可变气门正时及升程2.4L i-VTEC高性能发动机。
Odyssey is a car launched by Honda, which was launched nationwide in January 2007. It is equipped with satellite navigation system, 8-inch large display and sound guidance function, and uses variable valve timing and lift 2.4L i-vtec high-performance engine.
自从把我的车改装以后,身边的许多朋友纷纷向我咨询如何改装?在这其中咨询最多的也就是避震器改装的问题。 我自认为,在日常的改装中如果更换了一套好的避震系统,以后的改装空间就会缩小很多,即可以尽情发挥。但怎么选择一套适合自己的避震器呢?其中的门道有不少。
Since I refitted my car, many of my friends have asked me how to refit it? In this one of the most consulting is the problem of shock absorber modification. I think that if a good shock absorption system is replaced in the daily refitting, the refitting space will be reduced a lot in the future, that is, we can give full play to it. But how to choose a suitable shock absorber? There are many of them.
气动避震的组成部分分为控制系统和气动避震桶身两大类!
The components of pneumatic shock absorber are divided into control system and pneumatic shock absorber barrel!
Let's talk about the pneumatic shock absorption control system. Now the mainstream control system is divided into two types, namely, the one with memory mode and the one without memory mode. The one with memory mode has to mention the control system of airbft first. It should be the first system to enter China. Its stability and convenience are trusted and liked by many riders! Let's talk about its function and intelligence!
气动避震器就是安装在汽车悬挂上的空气避震器,它利用橡胶气囊来代替原厂的弹簧,并通过控制器的控制来调节底盘的高度。这简单的一句话概括了气动避震系统的两大组成部分——一部分是悬挂,一部分是控制器。
Pneumatic shock absorber is an air shock absorber installed on the automobile suspension. It uses rubber air bag to replace the spring of the original factory, and adjusts the height of the chassis through the control of the controller. This simple sentence summarizes the two major components of the pneumatic shock absorber system -- one is the suspension, and the other is the controller.
