查看: 580|回复: 0
重塑潮流,型格肆意宝马1系E87改装AIRBFT气动避震悬挂打造完美新看点
发表于 2021-5-16 13:31:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Reshaping the trend and style, BMW 1 series E87 refits airbft pneumatic suspension to create a perfect new look
潮流当道,劲装登场。BMW 1系 动曜夜版,集先锋美学与独到设计于一身,匹配飒爽果敢的强烈性格。全新运动曜夜套装,带来18英寸M铝合金轮毂与双边熏黑涂装排气尾管,运动气息再度提升,带黑色涂装的更大尺寸全新双肾型进气格栅与全新后视镜,释放由内而外的动感气息。新增多种个性车色,尽情表达率性自我。更多细节的先锋设计,打造强势颜型,所到之处,皆以惊艳气质捕获众人目光。
The trend is in the right place and the best clothes are on the stage. BMW 1 series dynamic Yao night edition, a combination of avant-garde aesthetics and unique design, matches the strong character of Sassou and bold. The brand-new sports Obsidian suit brings 18 inch m aluminum alloy wheel hub and exhaust tailpipe with double side blackening coating, which improves the sports atmosphere again. The larger size brand-new double kidney type air intake grille with black coating and brand-new rear-view mirror release the dynamic atmosphere from the inside out. Add a variety of personalized car colors to express yourself freely. More details of the pioneer design, to create a strong face, everywhere, with amazing temperament to capture people's attention.
现在的这个时代以低为美,一低遮三丑,趴在地上的车越来越多,如果你拥有一台宝马1系,你还没有改装,那么就奥特了吧,赶快看看这些宝马1系E87玩家是如何对自己的爱车进行改装的吧,
In today's era, low is the beauty. One low covers three ugliness. There are more and more cars lying on the ground. If you have a BMW 1 series and you haven't refitted it yet, let's see how these BMW 1 series E87 players refit their favorite cars,
