查看: 615|回复: 0
行政车的蜕变迈腾B8改装气压避震无法掩饰的低趴魅力
发表于 2021-5-13 15:45:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The transformation of the executive car, the low lying charm that can't be covered up by the refitting of maiteng B8 pneumatic shock absorber
作为大众全球领先的MQB B平台最新力作,全新一代迈腾是一款既能彰显商务身份,领导者气魄,又能兼顾年轻风尚品位生活的精英专属座驾,全新一代迈腾为追求高品质汽车生活的精英人群带来了一份惊喜,一份期待。
大众集团第六代B级车于2005年上市,2007年,由一汽-大众引进国内生产,命名迈腾。
As the latest masterpiece of the world's leading MQB platform of Volkswagen, the new generation of maiteng is an elite exclusive car that can not only show business identity and leadership spirit, but also give consideration to the young fashion and taste of life. The new generation of maiteng brings a surprise and expectation to the elite who pursue high-quality automobile life.
Volkswagen Group's sixth generation B-class car was launched in 2005. In 2007, it was introduced into China by FAW Volkswagen and named maiteng.
Many friends around me bought their own car. I have been asked how to modify and where to change the problem. Among them, the most consulted is the problem of retrofitting the shock absorber. However, it is no wonder that the most important part of the retrofit of the vehicle shock absorber is the hot spot area with high price. I think that if a good shock avoidance system is replaced in the daily street car refitting, the space for the future modification will be reduced a lot, so that it can be fully played out. But how to choose a suitable shock absorber for yourself? There are many doorways.
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system, In fact, the principle of air shock absorber is very similar to that of common shock absorber, coil spring + shock absorber, except that the distance between the car body and the ground can be adjusted by changing the volume of the air chamber (up and down direction), and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the air vent of the shock absorber can be changed by the motor, so as to adjust the damping force of the shock absorber, Can provide better performance, eh! So confident!
