查看: 514|回复: 0
 偶遇经典奔驰W124改装气动避震新姿态完美的身姿释放不可阻挡的魅力
发表于 2021-5-13 14:27:24 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Meet the classic Benz W124 by chance, refit the pneumatic shock absorber with new posture, release the irresistible charm with perfect posture
说到如今的奔驰 E 级车,那不得不提的就是当年经典的 W124。这款被看做是奔驰 E 级车正式开启的“第一款 E 级车”,在诞生之初就引发强烈关注。而在后续的一系列经典 E 级车,都可以说是在 W124 的光芒下显得更加引人注目。
When it comes to today's Mercedes Benz E-class cars, we have to mention the classic W124. This is regarded as the "first E-class car" officially launched by Mercedes Benz E-class car, which aroused strong attention at the beginning of its birth. In the subsequent series of classic E-class cars, it can be said that they are more attractive under the light of W124.
我经常看一些国外的改装案例,很多车辆都会让人深度着迷,不同于国内大批量“同化”的家用车,国外人更希望自己的爱车成为“买菜车”中最稀有的一辆,当然改装文化氛围的不同也有着很多各方面因素的影响,但是我们都是希望自己的座驾在吸引更多路人目光的同时,也能和大家分享改装的魅力!
I often look at some foreign refitting cases. Many vehicles are deeply fascinating. Different from the large number of "assimilated" domestic family cars, foreign people prefer their car to be the rarest one among the "vegetable shopping cars". Of course, the different refitting cultural atmosphere also has many factors, But we all hope that our car can attract more passers-by's attention and share the charm of refitting with you!
3: Responsible installation and modification shop, handling every detail, checking before delivery, air leakage, loose abnormal noise, damping height!
4: Before refitting, what you need, how you want to play, whether you want the effect after installation, and whether you have the convenience in the process of use
