查看: 676|回复: 0
岁月带不走的经典--BMW E30改装气动避震低姿态充满动感魅力
发表于 2021-5-13 13:47:01 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
A classic that can't be taken away by years -- BMW E30 modified pneumatic shock absorber, low profile, full of dynamic Charm
宝马E30算是第一代宝马3系,距今已经有30多年的时间,可谓经过了岁月的冲刷和洗礼。每当人们谈起老款宝马的时候, 亦或者底盘代号朗朗上口的经典车大神,  这就是经典, 今天给大家分享的就是宝马E30改装外观姿态的经典回归,诱惑低姿态完全看不出岁月的沧桑感!
BMW E30 is the first generation of BMW 3 series. It has been more than 30 years since then. It can be said that it has been washed and baptized by years. Whenever people talk about the old BMW, or the catchy chassis code name of the classic car God, this is the classic. What I want to share with you today is the classic return of BMW E30's modified appearance and posture. The temptation of low-profile can't see the vicissitudes of time!
From th first time I saw the car refitted by pneumatic shock absorber to now, I can't extricate myself from it. I have also experienced a lot of twists and turns! Also learned a lot about pneumatic shock absorption refit knowledge!
Let's talk about the pneumatic shock absorption control system. Now the mainstream control system is divided into two types, namely, the one with memory mode and the one without memory mode. The one with memory mode has to mention the control system of airbft first. It should be the first system to enter China. Its stability and convenience are trusted and liked by many riders! Let's talk about its function and intelligence!
There are three main options for refitting shock absorbers: competitive short spring, suit and twisted teeth. These functions are different, and the prices are quite different. The most important thing is to choose a shock absorber that suits you best. So what is the right shock absorber for you? After replacing and refitting the shock absorber, the first thing you have to bear is the loss of comfort. So if you still pursue the comfort of the vehicle, I suggest you not to replace it. If there is no problem with a little loss, replacing the set can not only improve the handling of the vehicle, but also not lose too much comfort. Because the appearance of the suit is to improve the handling performance of the vehicle on the large structure of the original shock absorber. However, there are also many shortcomings in shock absorber suits. First, the price is slightly expensive. Second, the damping and height can not be adjusted. Third, at present, the main brands of shock absorber suits are still concentrated in European cars, while Japanese car suits are not popular. However, for many senior players, shock absorbers can no longer meet their needs, so tooth twisting shock absorbers have become their first choice. In fact, the word "twisted teeth" comes from Hong Kong, China. Its real full name is height. Adjustable. Damper, which has the meaning of adjustable number of damper segments and body height. Seeing this name, I don't think I need to introduce its functions too much. It's all reflected in the name. However, Xiaobian still needs to add that although the ideal body height and handling performance can be obtained after replacing the hinged tooth shock absorber, it is built on the loss of 60% comfort, so it is best to be prepared before replacing it
