查看: 613|回复: 0
经典本田6代雅阁改装AIRBFT气动避震15年的陪伴终于让他灵魂复苏
发表于 2021-5-7 15:49:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The company of classic Honda 6 generation Accord refitting airbft pneumatic shock absorber for 15 years finally revived his soul
第六代 1999-2002年 正式开启中国市场,起步就与世界同步
发展至此,雅阁已经成为一部世界车型,因此“开发符合世界各地不同需求的通用型柔性平台”成为第六代雅阁的主题,务求提供行驶、安全、环保等各方面更加先进的性能。1999年,广汽本田开始国产此车型,是当时中国市场车型先进、技术卓越的中高级轿车。
The sixth generation officially opened the Chinese market from 1999 to 2002, and started at the same time with the world
So far, accord has become a world model, so "developing a universal flexible platform to meet the different needs of the world" has become the theme of the sixth generation Accord, in order to provide more advanced performance in driving, safety, environmental protection and other aspects. In 1999, GAC Honda began to make this model domestically. It was a medium and high-class car with advanced model and excellent technology in the Chinese market at that time.
对于一些已经老车,想要好好的玩 , 第一步就是改装,想要老车有范外观姿态不能少,低趴改装是最显效果的,所以现在很多玩老车的第一步就是改装气动避震悬挂,让车子趴下来!看看今天这辆六代雅阁有怎样的效果!
For some old cars, if you want to have a good play, the first step is to refit them. If you want old cars to have a good appearance and posture, you can't do less. Low lying refitting is the most effective, so now the first step for many old cars is to refit the pneumatic suspension to make them lie down! Look at the effect of this six generation Accord today!
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system, In fact, the principle of air shock absorber is very similar to that of common shock absorber, coil spring + shock absorber, except that the distance between the car body and the ground can be adjusted by changing the volume of the air chamber (up and down direction), and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the air vent of the shock absorber can be changed by the motor, so as to adjust the damping force of the shock absorber, Can provide better performance, eh! So confident!
