查看: 455|回复: 0
别克君威改装气动避震悬挂焕发低趴姿态新魅力
发表于 2021-5-7 15:25:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Buick Regal refits the pneumatic suspension and radiates the new charm of low lying posture
作为别克品牌最成功的战略车型之一,君威凭借潮流、动感、科技的产品形象和全面的技术实力深受用户青睐。别克君威汇聚通用汽车全球先进技术,在承袭传统优势的同时,针对新时期消费者不断提升的用车需求,以革新的产品实力带来新驾值之美,实现动感型格、驾乘品质、科技属性的再次进化。
As one of the most successful strategic models of Buick brand, Regal is favored by users with its product image and comprehensive technical strength of fashion, dynamic and technology. Buick Regal brings together the global advanced technology of general motors. While inheriting the traditional advantages, Buick Regal brings the beauty of new driving value with its innovative product strength to meet the increasing demand of consumers in the new era, and realizes the re evolution of dynamic style, driving quality and technological attributes.
俗话说“百改降为先,一低遮百丑”君威改装AIRBFT气动避震很好的应验了这一点,避震悬挂系统的改装,在汽车的改装除了发动机改装,应该也算是个大的手术了!下面就一起来看一下君威改装气动避震的低趴姿态……
As the saying goes, "one hundred changes first, one low cover one hundred ugly" Regal refit airbft pneumatic shock absorption well fulfilled this point, the refit of shock absorption suspension system, in addition to engine refit in car refit, should also be regarded as a big operation! Now let's take a look at the low prone posture of Regal modified pneumatic shock absorber
1: Main functions: four wheel independent lifting, front and back independent lifting, overall lowering; Air tank pressure is adjustable, air pump working setting, three-stage memory, mobile phone app remote control, automatic ignition up, automatic flameout low prone, support Chinese, English and other languages, remote control panel with LCD display, mainly display 4-wheel air bag pressure value and cylinder pressure value, more safe to feel the pneumatic shock culture for your car fun.
The installation of pneumatic shock absorber will link a control remote controller in the car. You can set several gears according to your own requirements. You can quickly switch between a variety of heights. In this way, you can make the car "lie down" on the ground when parking and rise to the normal driving height when driving normally.
