查看: 552|回复: 0
宝马-Z3 M-coupe底盘升降完美的低趴姿态从改装气动避震做起
发表于 2021-5-7 14:46:40 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Bmw-z3 m-coupe chassis lifting perfect low prone posture, starting from the modification of pneumatic shock absorber
作为一个九零后,今天要向大家说的这台车对于我来说或许有些陌生,这是活在七零后八零后宝马迷心中的神车。宝马Z3诞生于上世纪90年代, 精致的双肾造型堪称经典。九十年代,小跑车风席卷全球,Z3是宝马首款大批量生产的现代小型跑车,也是宝马首款在美国生产的跑车。Z3受欢迎不仅仅因为它的外观设计,更重要的是它出现在了007系列电影《黄金眼》中,虽然画面不多,但足以证明它是万众瞩目的。
As a post-90s, the car I want to tell you today may be a little strange to me. It's a magic car that lives in the hearts of the Post-70s and post-80s BMW fans. BMW Z3 was born in the 1990s, and its exquisite double kidney shape can be called a classic. In the 1990s, the trend of trot swept the world. Z3 is BMW's first mass-produced modern small sports car and BMW's first sports car made in the United States. Z3 is popular not only because of its appearance design, but also because it appeared in the 007 series film "golden eye". Although there are not many pictures, it is enough to prove that it is the focus of attention.
衡量一台车的优秀与否,那就要看整台车的姿态和气质,”无有比其容貌,特以姿态见美“眼前的这台宝马3系很好地诠释着这点!改装气动避震,以极致的视觉冲击和静态下完全俯身趴地的的姿态而著名!
To judge whether a car is excellent or not, it depends on the posture and temperament of the whole car. "There is nothing like its appearance, especially the beauty of its posture." the BMW 3 Series in front of us explains this very well! Modified pneumatic shock absorbers are famous for their extreme visual impact and static posture!
Airbft pneumatic special barrel is produced by SF shock absorption factory in Taiwan. Shanghai airbft pneumatic shock absorption operation center provides the most accurate model data. The customized pneumatic special barrel is 100% guaranteed to be used for special vehicles. Each model of airbft pneumatic shock absorption has undergone strict testing and adjustment, accurate installation position and perfect comfort, Let players in the pursuit of extreme posture at the same time to create perfect comfort and control for you, so that pneumatic shock absorber is not embroidered pillow, the real practical perfect.
AIRBFT专用气囊:像AIRBFT专车专用皮囊,所采用的天然胶成分比轮胎天然胶成分还要多!单个疲劳次数3百万次到5百万次,正常使用3-5年没有问题!所有的气囊都是经过严格的测试设备来进行试压 饱压才能配套出售!在皮囊的卡箍环节经过高压力的锁紧设备压紧,正常试压在200PSI,防爆破!皮囊外层有防腐蚀 防雨水 防沙尘 耐磨材料层层保护!给你最安全的保障
Airbags: like airbft special car bags, the natural rubber components used are more than the natural rubber components of tires! Single fatigue 3 million times to 5 million times, normal use 3-5 years no problem! All airbags are tested by strict testing equipment. Only when they are full can they be sold! The clamp link of the leather bag is compressed by high pressure locking equipment, and the normal pressure test is 200 psi, which is explosion-proof! The outer layer of the leather bag is protected by anti-corrosion, anti rain water, anti dust and wear-resistant materials! Give you the safest protection
