查看: 635|回复: 0
“疯狂保姆车”埃尔法改装气动避震控制系统完美施展个性低趴姿态
发表于 2021-5-7 14:13:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Crazy nanny car" ELFA refits pneumatic shock absorption control system, perfectly displays personality low prone posture
埃尔法豪华商务车,移动的大面包,这款车玩改装肯定属于另类,但是冷门也会有爆款出现,国内也有几台改的非常不错的埃尔法, 今天这台埃尔法安装AIRBFT气动避震悬挂套件,玩姿态的同时提升一些舒适何乐而不为!
ELFA luxury business car, mobile bread, this car is definitely an alternative, but there will be popular models. There are also several very good ELFA in China. Today, this ELFA is equipped with airbft pneumatic suspension kit, which can improve some comfort while playing!
From the first time I saw the car refitted by pneumatic shock absorber to now, I can't extricate myself from it. I have also experienced a lot of twists and turns! Also learned a lot about pneumatic shock absorption refit knowledge!
改装避震器主要选择分三种,分别是竞技短弹簧,套装,绞牙。这几种功能不同,价格也相差不少。选择适最适合自己的一款避震才是最重要的。那到底什么是适合自己的避震器呢?更换改装避震器后,首先要承担的就是舒适度损失,所以如果你还是对车辆舒适性比较追求的话那么在这里小编建议你还是不要更换的好,如果稍微损失一些没有什么问题的话,更换套装不仅可以提高车辆的操控性而且不会损失过多的舒适性。因为套装的出现,就是为在原车避震器的大结构上提高车辆的操控性能。不过避震套装也有许多不足,第一,售价略贵、第二,阻尼以及高低不可调整,第三,目前避震套装的选择,主要品牌还都集中在欧系车中,日系车套装并不热门。不过可能对许多资深玩家来说,避震套装已经完全不能够达到他们的需求,那么绞牙避震就成了他们的首选。绞牙这个词其实来源于中国的香港,其真正全称为Height. Adjustable. Damper有可调避震器阻尼段数以及车身高度的含义。看到这个名称我想我也没必要过多介绍它的功能了,全在名字里体现了。不过小编还是要插一句,更换绞牙避震后虽然可以得到理想的车身高度以及操控性能,但是却建立在损失百分之60的舒适上,所以更换前最好做好心理准备。
There are three main options for refitting shock absorbers: competitive short spring, suit and twisted teeth. These functions are different, and the prices are quite different. The most important thing is to choose a shock absorber that suits you best. So what is the right shock absorber for you? After replacing and refitting the shock absorber, the first thing you have to bear is the loss of comfort. So if you still pursue the comfort of the vehicle, I suggest you not to replace it. If there is no problem with a little loss, replacing the set can not only improve the handling of the vehicle, but also not lose too much comfort. Because the appearance of the suit is to improve the handling performance of the vehicle on the large structure of the original shock absorber. However, there are also many shortcomings in shock absorber suits. First, the price is slightly expensive. Second, the damping and height can not be adjusted. Third, at present, the main brands of shock absorber suits are still concentrated in European cars, while Japanese car suits are not popular. However, for many senior players, shock absorbers can no longer meet their needs, so tooth twisting shock absorbers have become their first choice. In fact, the word "twisted teeth" comes from Hong Kong, China. Its real full name is height. Adjustable. Damper, which has the meaning of adjustable number of damper segments and body height. Seeing this name, I don't think I need to introduce its functions too much. It's all reflected in the name. However, Xiaobian still needs to add that although the ideal body height and handling performance can be obtained after replacing the twisted tooth shock absorber, it is built on the loss of 60% comfort, so it is best to be prepared before replacing.
