查看: 454|回复: 0
VW尚酷改装气动避震个性造型立竿见影低姿态直逼超跑
发表于 2021-5-7 13:46:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
VW Shangku refits pneumatic shock absorbers, makes an immediate effect, and makes a low-profile approach to super run
正如它的名字——“沙漠热风”一样,三十年前Scirocco凭借具有前瞻性的楔形造型及大众汽车第一辆前轮驱动轿跑车的理念,迅速席卷跑车界。三十年后,传世轿跑Scirocco以富于未来感的外形设计及激情四溢的驾驭感受全新亮相,再次引来全球汽车发烧友的热望,并且还拥有了一个时尚与激情的中文名字——尚酷!时光流转三十年,唯一不变的就是Scirocco为全球车迷带来的精彩体验。
Just like its name - "Desert Hot Wind", Scirocco swept the sports car industry 30 years ago with its forward-looking wedge shape and the concept of Volkswagen's first front wheel drive coupe. Thirty years later, Scirocco, with its futuristic shape design and passionate driving experience, has once again attracted the enthusiasm of global car enthusiasts, and also has a fashionable and passionate Chinese name - Shangku! After 30 years, the only constant is the wonderful experience Scirocco has brought to the world's car fans.
VW尚酷外观上有着“最动感大众车”之称,  百公里加速成绩对于这样的小钢炮而言动力相当充沛。不过对于改装玩家来说,性能并不都是唯一取向,改装可能并不是简单的更快,享受一下姿态带给你的吸引力,来套气动避震玩低趴也是不错的选择。
VW Shangku is known as "the most dynamic Volkswagen car" in appearance, and its 100 km acceleration performance is quite powerful for such a small steel gun. However, for refitting players, performance is not always the only orientation. Refitting may not be simple and faster. It's also a good choice to enjoy the attraction of posture and play low lying with pneumatic shock absorbers.
3: Responsible installation and modification shop, handling every detail, checking before delivery, air leakage, loose abnormal noise, damping height!
4: Before refitting, what you need, how you want to play, whether you want the effect after installation, and whether you have the convenience in the process of use
