查看: 682|回复: 0
奥迪A4改装气动避震低姿态完美无缺
发表于 2021-5-6 14:12:05 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
奥迪A4改装气动避震低姿态完美无缺
Audi A4 refitted pneumatic shock absorber with perfect low profile
奥迪A4(Audi A4)是由一汽大众公司制造并于2003年4月上市的一款B级车型。
作为率先引入长轴距和涡轮概念的车型,从B5到B8,A4L的销量一直经久不衰。新款A4舍弃了泪眼设计,增加了quattro四驱模式,外形更加时尚运动,动力和操控性更加出众。车型内饰做工精致,科技配置丰富,空间充裕,在B级车型中拥有较好的实用性。
Audi A4 is a B-class car made by FAW Volkswagen and launched in April 2003.
As the first model to introduce the concept of long wheelbase and turbine, from B5 to B8, the sales volume of A4L has been enduring. The new A4 abandons the tearful eye design and adds Quattro four-wheel drive mode, which makes the appearance more fashionable and sporty, and makes the power and handling more outstanding. With exquisite interior workmanship, rich technology configuration and abundant space, the car has good practicability in class B models.
这些年,“百改降为先”成为了很多车友玩改装车的口头禅,让车子降低的方法有很多种,比如更换绞牙避震,换短弹簧等,但是车主为什么单单选择气动避震呢? 想要降低车身还不想丧失原有的通过性,那就是底盘升降,改装气动避震了,气动避震 其实原理并不难理解,就是通过储气泵向气囊中充气、放气实现自由升降车身的目的。
Over the years, it has become a catchphrase for many riders to refit their cars. There are many ways to lower their cars, such as replacing the twisted teeth for shock absorbers and replacing the short springs. But why do car owners only choose pneumatic shock absorbers? If you want to reduce the car body, you don't want to lose the original trafficability, that is, chassis lifting and refitting pneumatic shock absorbers. In fact, the principle of pneumatic shock absorbers is not difficult to understand, that is, the purpose of freely lifting the car body is to inflate and deflate the air into the air bag through the air storage pump.
