查看: 589|回复: 0
十代思域改装气动避震完美低趴展示无限低姿态魅力
发表于 2021-5-5 15:43:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ten generations of civic refitted pneumatic shock absorber, perfectly low lying, showing infinite low profile Charm
2016年4月12日,新思域是本田第十代Civic的国产版车型,采用了更加年轻运动化的设计,动力上将搭载1.5T和1.0T发动机,前期先推1.5T车型,搭载6速手动或者CVT变速箱。
On April 12, 2016, the new Civic is the domestic version of Honda's 10th generation Civic, which adopts a younger and sportier design. It will be powered by 1.5T and 1.0T engines. In the early stage, the 1.5T model will be launched first, and equipped with 6-speed manual or CVT transmission.
随着汽车文化的发展,十代思域早已有各种改装案例,相信不少车友都已观看过国外的改装思域。所谓车未到,改件先到。这辆十代思域改装AIRBFT气动避震悬挂低趴效果可谓相当不错,十代思域外观设计时尚超前,改装外观姿态可谓相当不错的选择!来欣赏这辆思域的完美低趴案例
With the development of automobile culture, there have been various refitting cases for the ten generation Civic. I believe many riders have watched refitting civic abroad. The so-called car does not arrive, change the first to arrive. The low lying effect of the modified airbft pneumatic suspension of the 10th generation Civic is quite good. The appearance design of the 10th generation Civic is fashionable and advanced, and the modified appearance posture is quite a good choice! To enjoy the perfect low lying case of Civic
