查看: 4333|回复: 0
沧桑的经典高尔夫4AIRBFT气动避震低姿态施工
发表于 2021-5-4 15:35:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Classic golf in vicissitudes: low profile construction of 4airbft pneumatic shock absorber
高尔夫4在飞速发展的今天可以说已经算是老车子了,这样的车子只有在热爱汽车改装文化的车友手中,下面的这台改装AIRBFT气动避震的高4, 不外乎两种路线,性能和外观 ,可谓是两者兼得,也是为了气动避震改装的低姿态能做到极致!焕发出新的光彩!
Golf 4 in the rapid development of today can be said to be an old car, such a car is only in the hands of car lovers who love car modification culture, the following modified airbft pneumatic shock absorber high 4, no more than two routes, performance and appearance, can be said to have both, but also for the low attitude of pneumatic shock absorber modification can achieve the ultimate! Glow with new brilliance!
1: Main functions: four wheel independent lifting, front and back independent lifting, overall lowering; Air tank pressure is adjustable, air pump working setting, three-stage memory, mobile phone app remote control, automatic ignition up, automatic flameout low prone, support Chinese, English and other languages, remote control panel with LCD display, mainly display 4-wheel air bag pressure value and cylinder pressure value, more safe to feel the pneumatic shock culture for your car fun.
The installation of pneumatic shock absorber will link a control remote controller in the car. You can set several gears according to your own requirements. You can quickly switch between a variety of heights. In this way, you can make the car "lie down" on the ground when parking and rise to the normal driving height when driving normally.
