查看: 545|回复: 0
最完美的C级 奔驰C250气动避震悬挂低姿态改装颜值提升
发表于 2021-5-4 14:48:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The most perfect C-class Mercedes Benz C250 pneumatic suspension, low profile modification and appearance improvement
作为史上最完美的C级,统一的家族设计运动而优雅,轿跑造型让它被受青睐,而空气悬架等等接近 的配置同样非常迷人。 改装气动避震是为了玩低姿态和体验底盘升降的乐趣,能升能降绝对的高逼格利器,奔驰C级改装气动避震悬挂完美演绎HellaFlush风格
魅力!
As the most perfect C-class car in history, the uniform family design is sporty and elegant. The car styling makes it popular. The air suspension and other similar configurations are also very attractive. The purpose of refitting pneumatic shock absorber is to play low posture and experience the fun of chassis lifting. It is a high-pressure grizzly tool that can lift and lower absolutely. Mercedes Benz C-class refitted pneumatic shock absorber suspension perfectly performs Hella flush style
HellaFlush的主要特征:
Hellaflush has become an international appearance trend of refitted cars. With the development and progress of domestic refitted cars, more and more people accept it. HF model has become a symbol of taste
The main features of hellaflush are as follows:
1. The central idea of hellaflush is offset is everything. The wheel hub uses an offset value that is more stretched than the normal value, so that the wheel hub is beyond the coverage of the body fender.
2. The distance between the wheel eyebrow and the wheel hub should be as small as possible. To complete this task, the car body should be lowered to a height that does not conform to the daily use, so that some HF style cars can't drive at all, so they have to use a trailer to pull the orz. As for how to lower the car body, there is no standard. Pneumatic shock absorbers, twisted teeth shock absorbers, short springs, or even modified sheep horns, you can do anything to achieve your goal.
3. As a result of the first two points, if the tire wants not to be rubbed and burst by the fender, it must use a specification narrower than the width of the wheel hub, so that the edge of the tire can be retracted so that it can be completely hidden in the fender. Of course, the fender can also be rolled in or expanded to a certain extent according to the protruding degree of the wheel hub.
4. If you want to have more attitude than attitude, you can't take the normal road for the inclination value of the tire. Take off at minus 2 degrees (that is, the upper part of the track is narrow and the lower part is wide). The method can be to adjust the inclination rocker arm, gasket and change the sheep's horn. In a word, we can't see eye to eye with normal people.
5. Tire stretch refers to the effect of the narrow tire installed on the ultra wide wheel hub. It's not easy to achieve this effect. Choosing a variety of tires should be strictly calculated according to the width of the wheel hub. Because, too wide hub with a narrow tire, when the tire inflation may dislocation, so can let the tire according to the correct position taut on the hub depends on the technician's modification level.
