查看: 559|回复: 0
宝马5系GT改装AIRBFT气动避震展示极限贴地的低姿态魅力
发表于 2021-5-4 14:11:22 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW 5 Series GT modified airbft pneumatic shock absorber shows low profile charm of extreme close to the ground
宝马5系GT是宝马旗下的一款高端商务车,采用了和新7系相同的CLAR平台打造,由于采用了铝合金、高强度钢、碳纤维等材料,新车比上一代车型减重99.8kg(220磅)。
BMW 5 Series GT is a high-end business car owned by BMW. It is built on the same clar platform as the new 7 series. Due to the use of aluminum alloy, high-strength steel, carbon fiber and other materials, the new car weighs 99.8kg (220 pounds) less than the previous generation.
宝马5系GT作为宝马的主流车型,销量和市场反馈都很好,宝马5系的改装案例有很多,当下比较流行的低趴改装算是主流,针对自己的爱车进行了常规的改装,低趴的车身姿态当然来自AIRBFT气动避震, 让人心动不已,个性造型设计,没有比这更加浪漫 ,打造出不凡的改装案例!
BMW 5-series GT, as the mainstream model of BMW, has good sales and market feedback. There are many cases of BMW 5-series refitting, and the popular low prone refitting is regarded as the mainstream. The conventional refitting is carried out for the car. The low prone body posture of course comes from airbft pneumatic shock absorbers, which makes people excited. There is no more romantic personality design, Create an extraordinary modification case!
正所谓一低遮百丑,这几年HF改装火遍大街小巷,气动减震也是一夜变身改装界网红
As the saying goes, "one low covers all the ugly things." in recent years, HF refitting has become popular all over the streets, and pneumatic shock absorbers have become popular in refitting industry overnight
话说这是个什么东西呢?它其实是一套可以控制气压,改变车身高低的装置,与传说中的主动车身控制系统(ABC)类似,不过它的工作介质是气体,一般来说就是下图所示的这么一套家伙事,其中包括弹性橡胶气囊减震器,气压控制系统、后备箱储气罐,及电子控制系统等,它其实和空气减震的原理与常见减震器
螺旋弹簧+减震筒形式,原理十分类似,只不过,通过改变气室体积(上下方向),来调整车身离地距离并一定程度改变软硬特性,另外减震筒部分则可以由电机改变通气孔尺寸,从而调节减震器的衰减力,因此空气减震器往往,能提供更好的性能表现,嗯!就是这么自信!
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank, electronic control system, etc, It is actually the same as the principle of air shock absorber and common shock absorber
The principle of coil spring + shock absorber is very similar. However, by changing the volume of air chamber (up and down direction), the distance between the body and the ground can be adjusted, and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the air vent can be changed by the motor in the shock absorber, so as to adjust the damping force of the shock absorber. Therefore, the air shock absorber can often provide better performance, eh! So confident!
