查看: 758|回复: 0
大众辉昂改装气动避震低趴姿态范十足
发表于 2021-4-29 16:18:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
大众辉昂改装气动避震低趴姿态范十足
VW huiang refits pneumatic shock absorber and low prone posture
在2016日内瓦车展中,大众发布了旗下全新中大型轿车——PHIDEON,新车采用和奥迪A6相同的MLB平台打造,并将率先由上汽大众引入国内生产并销售。而在2016北京车展前的大众之夜上,上汽大众PHIDEON于中国正式首发,中文正式定名为"辉昂"。
由于辉昂英文名Phideon的发音与象征着誓约、忠诚与信仰的罗马女神—菲得斯FIDES发音接近,因此该车的名字意味着优雅和可靠。
At the 2016 Geneva auto show, Volkswagen released its new medium and large-scale sedan, phideon. The new car is built on the same MLB platform as Audi A6, and will be introduced into domestic production and sales by SAIC Volkswagen. On the eve of Volkswagen before the 2016 Beijing auto show, SAIC Volkswagen phideon officially launched in China, officially named "huiang" in Chinese.
Because the pronunciation of the English name phideon of huiang is close to that of fides, the Roman goddess symbolizing vows, loyalty and faith, the name of the car means elegance and reliability.
改装气动避震低姿态有多种选择,一种是原车改装了绞牙避震,直接在用原车的绞牙升级气囊。或者直接安装全套避震悬挂,这两种可以让车身降得很低,如果说那种更好一些,肯定是更换全套专用气动减震效果更好。今天我们来欣赏大众辉昂定制气动避震专用减震的低趴效果!不仅舒适好而且姿态效果完美!
There are many options for refitting pneumatic shock absorbers in low attitude. One is that the original vehicle is refitted with hinge shock absorbers, and the original vehicle's hinge is directly used to upgrade the air bag. Or directly install a full set of shock absorbers, which can make the car body lower. If that is better, it must be better to replace a full set of special pneumatic shock absorbers. Today we come to enjoy the low lying effect of the customized pneumatic shock absorber of Volkswagen huiang! Not only comfortable, but also perfect posture effect!
气动避震的组成部分为控制系统和气动避震桶身两大类!
The components of pneumatic shock absorber are control system and pneumatic shock absorber barrel!
Intelligent air replenishment and intelligent adjustment of car level: in fact, the functions of these two functions are probably the same. For example, when the car body is originally horizontal, a fat man sits in the rear seat, the height of the rear side will be reduced. At this time, the computer will detect the height change of the rear side and respond in less than a second, The two airbags in the back inflate to keep the body level!
The ignition will automatically rise to the set position height: such a function is that no matter what height you park, for example, the lowest or the highest, when you stop, get off and drive again, the system will automatically raise the car to the second gear position, that is, the normal car height! This has both advantages and disadvantages. For example, the road condition is very bad. There is no suitable parking space. When you park, you stop at the highest position. When you drive again, the system will automatically reduce. If you just park on a very high rural cement deceleration belt, it is very likely or direct bottoming! The advantage is that in a normal parking lot, the car stops to the lowest level. When you drive again, the train will automatically rise to the normal driving height at one o'clock. Think about how high the driving height is
One key to the lowest: a key, can reduce the car to the lowest state! There is a key on the control panel to lower. Press for 3 seconds, and the whole car will be kept to the lowest state! Why three seconds? Because this is to prevent misoperation, if your car is in the driving state, if any child or special circumstances accidentally touch the button which is lowered by this key, it is a very terrible thing, so the design will 100% avoid this situation, all the buttons you accidentally touch do not matter, as long as not long press will be OK!
