查看: 607|回复: 0
丰田威尔法改装气动避震很酷很拉风
发表于 2021-4-29 15:50:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
丰田威尔法改装气动避震很酷很拉风
It's cool and windy to refit the pneumatic shock absorbers in Toyota welfa
丰田威尔法是由一汽丰田从日本原装引进的豪华型MPV。 新款皇冠威尔法推出2.5L HV豪华版、2.5L HV尊贵版、2.5L HV至尊版三个配置, 丰田威尔法为埃尔法双擎的孪生车型,由一汽丰田引入国内,二者仅在外观有明显差异。
Toyota weilfa is a luxury MPV originally imported from Japan by FAW Toyota. The new crown will launch three configurations: 2.5L HV luxury version, 2.5L HV noble version and 2.5L HV supreme version. Toyota will is the twin model of ELFA twin engine, which was introduced into China by FAW Toyota. There is only obvious difference in appearance between the two.
也因为Vellfire(威尔法)比埃尔法更年轻的地位,其在改装市场中一直都非常活跃。 但它们的外观却不尽相同。当身边的朋友纷纷改装气动避震,展现独特的自我个性,威尔法双擎年轻时尚的外观,具备了满足个性需求的良好改装基础,给改装爱好者极大的发挥空间。
Vellfire has always been very active in the refitting market because of its younger position than ELFA. But they look different. When friends around them refit the pneumatic shock absorbers one after another to show their unique personality, the young and fashionable appearance of wilfal twin engine has a good refitting foundation to meet the needs of personality, giving refitting lovers great space to play.
First of all, the installation of pneumatic shock absorbers. The installation of pneumatic shock absorbers is actually the same as the replacement of ordinary twisted tooth shock absorbers. Shock absorbers are all installed in the original vehicle. What we need to pay attention to is to calculate the maximum and minimum range required by the owner according to the shock absorbers' travel, adjust the height of the throttle shock absorbers, and reserve the position of the air pipes, Generally, the air pipe is on the inside, and the rest is according to the normal shock absorption installation steps.
The laying of pipelines is a time-consuming work. The methods and ideas of every installation master are different. However, one principle to follow is to avoid the places where there may be dead bends or where the air pipe may be pressed or ground by the vehicle while driving, and to stay away from the exhaust, because the material of the air pipe is mostly high temperature, The best way is to follow the oil pipe.
It's very troublesome to move the lines along with the electrical circuits in the car. It's better not to cut off the main power line if you need to disassemble many interior parts. In addition, if there are other electrical equipment in the car, you must not share the power line to prevent mutual interference.
The installation of control system, airbft pneumatic shock absorption control system is quite simple control system, but want to perfect the installation still need to have some experience, there are a lot of details need to pay attention to, especially each joint and gas pipe and gas hole screw tooth connection, should be carefully installed, gas hole and joint screw tooth connection must be sealed, It should be that if there is air leakage, it is very troublesome to check and test again. Try to do it in one step.
