查看: 649|回复: 0
时尚传统风全新一代奥迪A6C8改装气动避震低趴旅行更显年轻范堪称完美
发表于 2021-4-28 14:50:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The new generation of Audi a6c8 is modified with pneumatic shock absorber, and the low lying travel is more youthful and perfect
奥迪A6作为奥迪家族中最具豪华气息的一员, 首次亮相于2018年广州车展的国产第五代奥迪A6C8于2019年1月份正式上市, 全新一代奥迪A6外观和内饰都发生了翻天覆地的变化,外观不再走沉稳的商务路线,传承了自家A8L上的全新家族式设计语言,但是在细节方面采用了更激进的设计,有着丰富的视觉冲击力。
As one of the most luxurious members of the Audi family, Audi a6c8, the fifth generation of domestic Audi a6c8, which first appeared in Guangzhou auto show in 2018, was officially launched in January 2019. The appearance and interior of the new generation of Audi A6 have undergone earth shaking changes. The appearance no longer takes a steady business line, and inherits the new family style design language on its A8L, But in the details of the more radical design, has a rich visual impact.
气动避震的改装是近几年在国内非常流行的一种改装方式,因为那难以抵挡的低姿态,很多车友不顾一切的改装气动避震来玩低趴,就像今天的这台奥迪A6C8,改装AIRBFT气动避震简直是颜值爆表! 整车气质立马有了一个飞跃!
In recent years, the modification of pneumatic shock absorber is a very popular modification method in China. Because of its low posture, many riders are desperate to modify the pneumatic shock absorber to play low lying. Just like today's Audi a6c8, the modification of airbft pneumatic shock absorber is just a beauty! Vehicle temperament has a leap immediately!
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system, In fact, the principle of air shock absorber is very similar to that of common shock absorber, coil spring + shock absorber, except that the distance between the car body and the ground can be adjusted by changing the volume of the air chamber (up and down direction), and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the air vent of the shock absorber can be changed by the motor, so as to adjust the damping force of the shock absorber, Can provide better performance, eh! So confident!
AIRBFT,相对于操控来说,那就它是一个四轮独立的水平记忆气动悬挂系统。何为四轮独立?就是相对于一些前后独立(我以前开始玩气动悬挂时就用过)的气动悬挂来说,就是每一个避震上的气囊都是单独一个电脑单元控制,单独的电磁阀控制,不会类似前后独立的系统一样两支避震的空气是流通的。这样就首先确保了每支避震确立了自己的独立工作,不会因为车身转向时的压力而把气压流通到不受压的避震气囊里面而产生一边高一边低的情况。水平记忆是一个气动悬挂系统的突破点,打破了老套的气压感应记忆,引入全新的,不会因为车辆载重之后导致记忆不准确的缺点,不管是高速过弯时车辆受力侧产生的压力还是载人后受重的情况下都可以稳定保持避震原先记忆的高度。
Airbft, relative to the control, is a four-wheel independent horizontal memory pneumatic suspension system. What is four rounds of independence? Compared with some front and rear independent pneumatic suspensions (which I used when I started playing pneumatic suspensions before), the air bag on each shock absorber is controlled by a separate computer unit and a separate solenoid valve, which is not the same as the front and rear independent systems. The air of the two shock absorbers is circulating. This first ensures that each shock absorber has established its own independent work, and will not flow the air pressure into the non pressurized shock absorber due to the pressure when the body turns, resulting in the situation of high side and low side. Horizontal memory is a breakthrough point of pneumatic suspension system, which breaks the old-fashioned air pressure induction memory and introduces a new one, which will not lead to inaccurate memory after the vehicle is loaded. Whether it is the pressure generated on the stressed side of the vehicle when cornering at high speed or the heavy load after carrying a person, it can stably maintain the original memory height of shock absorber.
