查看: 518|回复: 0
跑车中的淑女——NISSAN Fairlady气动避震悬挂激情改装诠释低姿态更胜一筹
发表于 2021-4-28 14:15:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The lady in the sports car-NISSAN Fairlady aerodynamic shock absorber suspension passionate modification interpretation of low profile better
Nissan这个品牌,第一印象就是大沙发,各项表现更为突出,在内外观设计或是动力性能上,都继承了Z车系一贯的设计与性能绝妙平衡,说的性能跑车或者是漂移那一定就是,  但在改装玩家发烧友心目中, NISSAN是时代最先端的梦幻经典跑车,改装气动避震低姿态更是让这辆经典跑车姿态更胜!
Nissan's first impression of the brand is the big sofa. Its performance is more outstanding. In terms of interior and exterior design or power performance, it inherits the excellent balance between the design and performance of Z car series. It must be the performance sports car or drift. But in the eyes of refitting players, Nissan is the most advanced dream classic sports car of the times, Refitting pneumatic shock absorbers to make this classic sports car more attractive!
Airbft pneumatic special barrel is produced by SF shock absorption factory in Taiwan. Shanghai airbft pneumatic shock absorption operation center provides the most accurate model data. The customized pneumatic special barrel is 100% guaranteed to be used for special vehicles. Each model of airbft pneumatic shock absorption has undergone strict testing and adjustment, accurate installation position and perfect comfort, Let players in the pursuit of extreme posture at the same time to create perfect comfort and control for you, so that pneumatic shock absorber is not embroidered pillow, the real practical perfect.
