查看: 382|回复: 0
斯柯达改装AIRBFT气动避震成就极致低趴醉美姿态
发表于 2021-4-27 16:28:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Skoda refits airbft pneumatic shock absorber to achieve the ultimate low posture
斯柯达(SKODA),德国大众汽车公司经典品牌之一,总部位于捷克姆拉达-博莱斯拉夫,是世界上历史最悠久的四家汽车生产商之一。该品牌创立于1895年。
斯柯达在100多年的发展历程中,经历了多次的战乱、政变和兼并,坚韧不拔地谱写出斯柯达辉煌的历史篇章,显示了惊人的生存功夫!目前,斯柯达的产品主要有柯迪亚克、柯迪亚克GT、柯米克、柯珞克、速派、明锐、明锐旅行车、昕动、昕锐以及晶锐  。并且有MissionLVisionC、VisionD、Vision S、CitiJet、Vision GT    、Vision iV  等概念车型研发。
Skoda, one of the classic brands of Volkswagen, is headquartered in mlada Boleslav, Czech Republic. It is one of the four oldest automobile manufacturers in the world. The brand was founded in 1895.
In the course of more than 100 years of development, Skoda has experienced many wars, coups and mergers. It has persevered in writing a brilliant chapter in Skoda's history, showing amazing survival skills! At present, Skoda's products mainly include Kodiak, Kodiak GT, komic, Kroc, Supai, Mingrui, Mingrui station wagon, Xindong, Xinrui and Jingrui. In addition, there are mission vision C, vision D, vision s, citijet, vision GT, vision IV and other concept models.
有车友会有这样的疑问,我的汽车在改装了气动避震后能让我使劲折腾吗?想跟朋友跑到外地去旅游,改装空气悬挂后能长时间的跑高速吗?听说气动避震改装比一般的避震娇贵些,我还能飙车吗?
Some car club have such a question. Can my car make me toss hard after refitting pneumatic shock absorbers? Want to travel with friends to other places, after refitting the air suspension, can you run high speed for a long time? It's said that pneumatic shock absorbers are more expensive than ordinary shock absorbers. Can I still drag racing?
在回答问题之前我们先了解一下为什么有人说气动避震比一般避震要娇贵些,因为气动避震比原厂避震有更加精密的零件,气动避震器上各带有气囊,利用气囊来减震比一般的减震要舒适,毕竟气体比较柔软嘛,成也萧何败萧何,在利用气囊带来的便利时汽车行驶也要有一些局限性,安装了气动避震的车辆只能在道路良好的路段行驶,因为气动避震经不起太剧烈的颠簸,所以一般只要在柏油马路上正常行驶都没有问题,跑跑高速去外地旅游当然没有问题了!
Before answering this question, let's first understand why some people say that pneumatic shock absorbers are more expensive than ordinary shock absorbers, because pneumatic shock absorbers have more precise parts than original shock absorbers. Pneumatic shock absorbers are equipped with airbags. It's more comfortable to use airbags for shock absorption than ordinary shock absorbers. After all, the air is softer and the success is bleak, When taking advantage of the convenience brought by the air bag, the car driving should also have some limitations. The vehicle equipped with pneumatic shock absorber can only drive in a good section of the road, because the pneumatic shock absorber can not withstand too severe bumps, so generally as long as the normal driving on the asphalt road is no problem, running high-speed travel to other places is certainly no problem!
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system, In fact, the principle of air shock absorber is very similar to that of common shock absorber, coil spring + shock absorber, except that the distance between the car body and the ground can be adjusted by changing the volume of the air chamber (up and down direction), and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the air vent of the shock absorber can be changed by the motor, so as to adjust the damping force of the shock absorber, Can provide better performance, eh! So confident!
