查看: 540|回复: 0
打造心目中的低姿态 福克斯改装气动避震肆意盎然魅力
发表于 2021-4-27 16:13:01 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Create a low profile fox in mind, refit pneumatic shock absorbers, wantonly full of charm
福特·福克斯 FOCUS的意思就是焦点。  福克斯作为福特旗下最畅销的紧凑型轿车,以其良好的底盘和操控性,提升了福特在全球市场的品牌地位。
1998年,福克斯问世,出色的操控性能和运动化的底盘调校使其快速风靡全球。2005年,福克斯携WRC世界越野拉力赛一身荣耀进入中国,到2019年已在CTCC中国房车竞标赛中获得了十三年九冠的传奇战绩,以“运动时尚”定义了运动轿车。  福克斯从第二代车型开始进入中国市场以后,以运动、操控见长和年轻、动感为主要形象,在国内紧凑级车型市场取得了良好的成绩,随着车型日益成熟,消费者的年龄层也产生着小幅变化,客户群的年龄范围更广。
Ford fox focus means focus. As Ford's best-selling compact car, fox has enhanced Ford's brand position in the global market with its good chassis and handling.
In 1998, fox came out, excellent control performance and sporty chassis tuning make it quickly popular all over the world. In 2005, fox entered China with the glory of WRC world cross-country rally. In 2019, fox has won the legendary record of nine Championships in 13 years in CTCC China RV competition, defining sports car with "sports fashion". Since fox entered the Chinese market with the second generation of models, it has made good achievements in the domestic compact model market with the main image of being good at sports and control, being young and dynamic. With the increasingly mature models, the age of consumers has also changed slightly, and the age range of customers is wider.
福克斯作为热门 改装车 型之一,民间案例多不胜数。尤其是经典改装福克斯,玩法多样,不论你是喜欢姿态改装,还是动力改装,都有成熟的方案。今天AIRBFT给大家带来一台福克斯低趴案例,满满的战斗范姿态让人不敢靠近。 稳定的性能,卓越的品质,四轮独立升降和三段记忆功能,是目前世界上最顶尖的一套空气悬挂产品,也是每个气动避震爱好者的梦想,再加上包围和前铲的贴地效果,效果更加的完美。
As one of the popular refitted models, fox has numerous folk cases. In particular, the classic modification fox, play a variety, whether you like posture modification, or power modification, there are mature programs. Today, airbft brings you a fox low lying case, full of fighting posture, people dare not get close. Stable performance, excellent quality, four-wheel independent lifting and three segment memory function, is the world's top air suspension products, but also the dream of every pneumatic shock absorber enthusiast, coupled with the surrounding and front shovel effect, the effect is more perfect.
3: Responsible installation and modification shop, handling every detail, checking before delivery, air leakage, loose abnormal noise, damping height!
4: Before refitting, what you need, how you want to play, whether you want the effect after installation, and whether you have the convenience in the process of use
