查看: 509|回复: 0
丰田凯美瑞改装气动避震下线 完美低趴姿态一鸣惊人
发表于 2021-4-27 15:54:15 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyota Camry modified pneumatic shock absorber offline, perfect low prone posture, a big hit
说起汽车改装,很多车友以为这都是那些百十万车子的专属,其实这是一个误区,越是豪车,它的改装空间就越小,越是价格亲民的大众车型,其改装空间和改装乐趣就越多!
下面的这台丰田凯美瑞,改装了气动避震,轮毂轮胎,刹车系统,出色的外观和低趴姿态,受到了很多车友的喜欢,气动避震改装的实用性和突出的视觉效果,是当下非常流行的改装方式,在国内的大小展会或者是车友聚会,大多都是以气动避震该转的低趴姿态为主!
Speaking of car refitting, many car friends think it is the exclusive of those hundreds of thousands of vehicles. In fact, this is a mistake. The more luxury cars are, the smaller the space for refitting, the more popular models with price relatives, the more space and fun they have to refit!
The following Toyota Camry, which has been modified with pneumatic shock proof, wheel hub tire, brake system, excellent appearance and low lying posture, has been liked by many car friends. The practicability and outstanding visual effect of the pneumatic shock avoidance modification are very popular retrofitting methods at present. It is a large and small exhibition or a car friends gathering in China, Most of them are mainly low lying posture of the pneumatic shock avoidance!
气动避震的组成部分为控制系统和气动避震桶身两大类!
The components of pneumatic shock absorber are control system and pneumatic shock absorber barrel!
Intelligent air replenishment and intelligent adjustment of car level: in fact, the functions of these two functions are probably the same. For example, when the car body is originally horizontal, a fat man sits in the rear seat, the height of the rear side will be reduced. At this time, the computer will detect the height change of the rear side and respond in less than a second, The two airbags in the back inflate to keep the body level!
The ignition will automatically rise to the set position height: such a function is that no matter what height you park, for example, the lowest or the highest, when you stop, get off and drive again, the system will automatically raise the car to the second gear position, that is, the normal car height! This has both advantages and disadvantages. For example, the road condition is very bad. There is no suitable parking space. When you park, you stop at the highest position. When you drive again, the system will automatically reduce. If you just park on a very high rural cement deceleration belt, it is very likely or direct bottoming! The advantage is that in a normal parking lot, the car stops to the lowest level. When you drive again, the train will automatically rise to the normal driving height at one o'clock. Think about how high the driving height is
One key to the lowest: a key, you can reduce the car to the lowest state! On the control panel, there is a one button to lower. Long press for 3 seconds, and the whole car will be in the lowest state! Why three seconds? Because this is to prevent misoperation. If your car is running, it's a terrible thing if a child or a special case accidentally touches the button with one button lowered. This design can completely avoid this situation. It doesn't matter if you accidentally touch all the buttons, as long as you don't press them for a long time!
