查看: 4244|回复: 0
大众桑旅AIRBFT气动避震改装施工进行中
发表于 2021-4-27 15:35:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Modification of airbft pneumatic shock absorber of Volkswagen sanglv is in progress
桑旅:也就是桑塔纳旅行车,通常人们都叫它“桑旅”。
它的原型车是德国大众公司的帕萨特b2。b2在德国本土只生产了13万辆,而作为第一款合资生产的轿车,桑塔纳在中国已经生产了19年,累计产量200多万台。19年间上海大众对桑塔纳不断进行改进,直到今天桑塔纳还在不停的驶下生产线。
Sanglv: that is, Santana station wagon. People usually call it "sanglv".
Its prototype is Volkswagen's Passat B2. B2 has only produced 130000 cars in Germany. As the first joint venture car, Santana has produced more than 2 million cars in China for 19 years. In the past 19 years, Shanghai Volkswagen has been improving Santana continuously. Up to now, Santana is still driving off the production line.
开不坏的桑塔纳,修不好的切诺基。”一句老话说出桑塔纳在老一辈人心目中优秀的形象,更何况还是一台旅行版的车款,而今天为大家带来的这台经过改装的桑塔纳旅行版更是以另类姿态赚取关注度。今天 欣赏这辆桑旅改装AIRBFT气压避震悬挂的魅力低姿态!
Santana can't be broken, Cherokee can't be repaired. " As an old saying goes, Santana has an excellent image in the eyes of the older generation, not to mention a travel version of the car. Today, the refitted Santana travel version is an alternative attitude to earn attention. Today, enjoy the charm and low attitude of this sanglv modified airbft pneumatic suspension!
The refitting of automobile chassis has a large proportion in the refitting industry. The chassis system of the original car can't meet the needs of the players now. Refitting is imperative. In recent years, the refitting of tooth twisting shock absorber is the mainstream choice of the players. It not only reduces the body, increases the aesthetic feeling, but also improves the vehicle control. However, the hardness is not acceptable to ordinary people, and the bad road makes tooth twisting party suffer, Now the emergence of pneumatic shock absorbers, so that the players to play twisted teeth to see a new dawn. The low lying effect when parking, and the car body can be raised when driving. It's really cool to lift at will. If the adjustment is good, the comfort is a little better than the tooth twisting. Now it has become a trend of chassis suspension modification. If the stability and comfort are better, it will become the most popular modification project in the future!
