查看: 351|回复: 0
姿态魅力 大众高尔夫气动避震改装玩低趴姿态风格
发表于 2021-4-27 15:22:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Posture charm public golf pneumatic shock absorption refit play low posture style
大众高尔夫(Golf)是一款由一汽-大众在1974年推出的经典掀背/小型家用车型。已经在全球市场推出了七代,是大众汽车公司生产最多的品种,也是大众最畅销的车型。在全球畅销车型中位列第三,到2007年总产量已经超过了2500万辆。 作为全世界最成功的车型之一, 每一代高尔夫的独特创新,都引领着汽车界的时尚风潮,并一次次成为德系车严谨态度与追求品质完美的代表作。
Volkswagen Golf is a classic hatchback / small family car launched by FAW Volkswagen in 1974. It has launched seven generations in the global market. It is the most popular product of Volkswagen and the best-selling model of Volkswagen. It ranks third among the best-selling models in the world, with a total output of more than 25 million by 2007. As one of the most successful models in the world, the unique innovation of each generation of golf has led the fashion trend in the automotive industry, and has become the representative work of German cars' rigorous attitude and pursuit of perfect quality.
气动避震属于一种外观姿态极致演绎,不同于原厂的空气悬挂,气动避震主要是用于低姿态的改装,升降行程较大,可以降得很低,想要升高的玩家也可以升高车身,但是舒适性却不如原车空气悬挂,偏硬,当然这跟调教和车型有关。不多说了,今天介绍的是高尔夫改装AIRBFT气动避震悬挂的低姿态魅力
Pneumatic shock absorption is a kind of extreme deduction of appearance and posture, which is different from the original air suspension. Pneumatic shock absorption is mainly used for low-profile modification. The lifting stroke is large, and it can be lowered very low. Players who want to raise can also raise the body, but the comfort is not as good as the original air suspension, which is hard. Of course, this is related to the adjustment and model. Not to mention, today we introduce the low-profile charm of golf modified airbft pneumatic suspension
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system, In fact, the principle of air shock absorber is very similar to that of common shock absorber, coil spring + shock absorber, except that the distance between the car body and the ground can be adjusted by changing the volume of the air chamber (up and down direction), and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the air vent of the shock absorber can be changed by the motor, so as to adjust the damping force of the shock absorber, Can provide better performance, eh! So confident!
首先,在更换车辆避震系统前一定要先知道更换的避震器的功能,以及你改装的需要。当然避震器的主要构成是由四个避震弹簧以及四只避震筒组合而形成,弹簧最主要的功用是用来消除行经不平路面的震动,我想这谁都知道。但许多人会问四只避震筒在车辆行进中又可以起到什么样的作用?其实避震筒的真正用途用来抑制弹簧吸震後反弹时的震荡和吸收路面冲击的能量。假如你开过避震器坏掉的车,你就可以体会车子通过每一坑洞、起伏後馀波荡漾的弹跳,而避震器正是用来抑制这样的弹跳。没有避震器将无法控制弹簧的反弹,车子遇到崎岖路面时将会产生严重的弹跳,过弯时也会因为弹簧上下的震荡而造成轮胎抓地力和循迹性的丧失,所以避震筒对车辆的操控力还是起着至关重要的作用。
First of all, be sure to know the function of the replaced shock absorber and the need of your modification before replacing the vehicle's shock absorber system. Of course, the main structure of the shock absorber is composed of four shock absorbers and four shock absorbers. The main function of the spring is to eliminate the vibration of the uneven road. I think everyone knows that. But many people will ask what role can four shock absorbers play when the vehicle is moving? In fact, the real purpose of the shock absorber is to suppress the shock when the spring rebounds after the shock absorption and absorb the energy of road impact. If you've ever driven a car with a broken shock absorber, you can experience the bouncing of the car through every hole and after the ups and downs, and the shock absorber is used to suppress such bouncing. Without the shock absorber, the rebound of the spring can not be controlled. When the car encounters a rough road, it will have a serious bounce. When it turns, it will also cause the loss of tire grip and tracking due to the vibration of the spring up and down. Therefore, the shock absorber still plays a vital role in the control of the vehicle.
