查看: 529|回复: 0
“牛魔王”Toyota supra改装AIRBFT气动避震悬挂低姿态诠释低趴精神
发表于 2021-4-27 14:32:50 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyota super refits airbft pneumatic suspension, low profile and low prone spirit
Supra是丰田公司的一款车型,源自Celica,甚至连最早的车型代号也从Celica手上夺了过来,第一代的Celica车架代号为TA22,后来的Celica才用上了“T”为产品编号。
Supra is a model of Toyota company, which originated from celica. Even the earliest model code was snatched from celica. The first generation celica frame code was ta22, and later celica used "t" as the product number.
有人说玩改装是为了装酷/撩妹,有人说玩改装是为了烧钱/追求刺激,每个人走进改装圈的理由并不相同。但大多数人都是浅尝辄止,从不深究背后的东西。就像改装圈里一直盛传着一句话,“百改降为先,一低遮百丑”,气动避震可以说是改装发烧友们最热衷的项目。可有多少人真正把它玩明白了呢?
Some people say that the purpose of refitting is to be cool / seductive. Others say that refitting is to burn money / pursue excitement. Everyone has different reasons to enter the refitting circle. But most people are superficial, never delve into the things behind. It's just like a popular saying in the refitting circle that "one hundred retrofits should be reduced first, one low should cover one hundred ugliness". Pneumatic shock absorbers can be said to be the favorite project of refitting enthusiasts. But how many people really understand it?
