查看: 630|回复: 0
奔驰CLS瓦罐姿态魅力蜕变改装气动避震
发表于 2021-4-15 15:51:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
奔驰CLS瓦罐姿态魅力蜕变改装气动避震
Mercedes Benz CLS can posture charm transformation refitting pneumatic shock absorber
奔驰CLS瓦罐车,也就是旅行版车型,虽然在国内还是偏向小众的车型,不过这两年在国内的可见度越来越高了,而且旅行车车型的改装率也很高。本期为大家带来奔驰CLS气动改装案例。
Although Mercedes Benz's CLS can car, that is, the travel version, is still a niche model in China, its visibility in China has become higher and higher in the past two years, and the modification rate of the travel car model is also very high. This issue brings you the case of Benz CLS pneumatic modification.
There has always been a saying in the car circle, "a low cover a hundred ugly." Such a famous saying. Even if the car is no longer good-looking, as long as the body is lowered, it can definitely improve the appearance of the car? The super run is low. So as a modification that can improve the appearance and control, how to modify the shock absorber?
外观上的另一特点就是停下后车身超低,这是气动悬架的功劳。这种几乎贴合地面的车身高度,使得这辆车具有了难以形容的美感,同时托了紫色车漆的福,让整车更加具有膨胀的感觉。当然在这种高度时,车辆是无法行驶的,因为整车底盘几乎完全贴地,中国的道路状况是无法满足它正常行驶的,如果非要开走恐怕这车到不了家就要报废了。但是众多的改装迷们,还是不遗余力地将车身高度尽可能降低,已达到更有“范儿”的效果,有可能因此丧失更多的驾驶乐趣,也不能改变他们“起范儿”的决心。这被我们戏称为“恐高症”
Another feature of the appearance is the ultra-low body after stopping, which is the credit of the pneumatic suspension. The height of the car body that almost fits the ground makes the car have an indescribable aesthetic feeling. At the same time, thanks to the purple paint, the whole car has a more expansive feeling. Of course, at this height, the vehicle can't drive, because the chassis of the whole vehicle is almost completely close to the ground. The road conditions in China can't meet its normal driving. If you have to drive away, I'm afraid the car will be scrapped if it can't get home. However, many refitting fans still spare no effort to reduce the height of the car body as much as possible to achieve a more "style" effect, which may lead to the loss of more driving pleasure, and also can not change their "style" determination. This is what we call "acrophobia"
Comfort and handling have always been the two core standards to measure the performance of a car. However, in the first hundred years of development of a car, the two have always been enemies in the eyes of designers, and it is difficult to give consideration to each other. In this regard, many automotive design masters have developed various technologies to solve this problem, but the most significant milestone is the advent of air suspension technology! Compared with the spiral spring suspension used in ordinary vehicles, the absolute advantage of air suspension is obvious. First of all, unlike spring, air has only one fixed stiffness, and its elastic coefficient can be changed through the adjustment of air valve and air pump. Accordingly, the soft and hard degree of the shock absorber can also be adjusted, making the comfort greatly increased. Secondly, the length and stroke of the air spring can also be controlled by the amount of compressed air. So we see a chassis that can be raised and lowered.
