查看: 599|回复: 0
潮流前线 奥迪A4B8改装AIRBFT气动避震 最美诱惑姿态
发表于 2021-4-15 15:10:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Trend front Audi a4b8 modified airbft pneumatic shock absorber
奥迪A4作为奥迪系列最畅销的一款车型,从外观设计到做工配置都相当的不错,改装潜力也是很大的,奥迪A4改装气动避震的案例在国内是最多的,好的案例多不胜数,流利的线条设计,让这个车改低姿态最具诱惑,今天我们来欣赏奥迪A4B8改装AIRBFT气动避震的诱人姿态。
As the best-selling model of Audi series, Audi A4 is quite good in appearance design, workmanship and configuration, and has great modification potential. The cases of Audi A4 modifying pneumatic shock absorbers are the most in China, and there are countless good cases. The fluent line design makes this car's low-profile most attractive. Today, let's enjoy the attraction of Audi a4b8 modifying airbft pneumatic shock absorbers Posture.
