查看: 404|回复: 0
VW scirocco气动避震改装展现一份独特的低趴范儿
发表于 2021-4-15 14:52:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
VW Scirocco pneumatic shock absorber refitting shows a unique low lying style
VW scirocco前脸上进气格栅采用了蜂窝状样式,而雾灯样式、大灯内部结构也有所调整。另外,该车还换装了更为运动的轮圈,突显运动感。从外观上看,尚酷身上有着所有“小钢炮”的特征,短轴距、无框车门、双门布局、低矮车身,还有着一副“杀气腾腾”的前脸,尾部设计的辨识度也非常高,大众尚酷无疑是大众在国内的一款成功的跑车车型,外观上有着最美大众之称。 不过对于某些改装玩家来说,改装才是中心。经过线条修饰的后尾设计,非常的惊艳,这一设计我个人非常的喜欢,不知道你们怎么看待?
The air intake grille on VW Scirocco's front face adopts honeycomb style, and the style of fog lamp and the internal structure of headlamp are also adjusted. In addition, the car is also equipped with more sporty wheels, highlighting the sense of movement. From the appearance point of view, Shangku has all the characteristics of "small steel cannon", such as short wheelbase, frameless door, double door layout, low body, and a "murderous" front face. The recognition degree of the rear design is also very high. Volkswagen Shangku is undoubtedly a successful sports car model of Volkswagen in China, and it is known as the most beautiful Volkswagen in appearance. But for some refitting players, refitting is the center. After the line modification of the tail design, very amazing, this design I personally like very much, do not know what you think?
AIRBFT专用气囊:
Airbft airbag:
