查看: 424|回复: 0
VW MK5改装气动减震经典低趴案例变身最美车型姿态
发表于 2021-4-15 14:22:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
VW MK5 modified pneumatic shock absorption classic low lying case to transform into the most beautiful vehicle posture
对于VW MK5,是一款十分经典的小钢炮车型,喜欢的人说它是大众造车工艺的巅峰之作,而不喜欢它的人说它已经失去了VW MK5原有的味道, 对于它的外形也是有些接受不了,可依然是很多改装爱好者心目中的梦想之车。 但不得不承认它是当时大众打造的一款非常卓越的车型,下面我就为大家介绍一款改装智能控制AIRBFT气动避震的VW MK5,来欣赏一下吧!
For VW MK5, it is a very classic small steel gun model. People who like it say that it is the peak of Volkswagen's car making technology, while people who don't like it say that it has lost the original taste of VW MK5 and can't accept its appearance, but it is still the dream car in the eyes of many refitting enthusiasts. But I have to admit that it was a very excellent model built by Volkswagen at that time. Now I will introduce VW MK5, which is refitted with intelligent control airbft pneumatic shock absorber. Let's enjoy it!
