查看: 525|回复: 0
宝马Z3亲身体验改装气动避震的舒适度怎么样
发表于 2021-4-15 13:45:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW Z3 experience the comfort of refitting pneumatic shock absorber
宝马Z3是宝马系列的一款车型。1996年5月,第一批宝马问世,很短时间内跃升为同类中最畅销的车型。
正所谓一低遮百丑,百改降为先,改装气动避震悬挂上车绝对是最好的选择!,看看宝马Z3 的气动避震低姿态魅力!
BMW Z3 is a model of BMW series. In May 1996, the first batch of BMW came out, and within a short time, it became the best-selling model of its kind.
As the saying goes, one low cover one hundred ugly, one hundred change first, refitting pneumatic suspension on the car is absolutely the best choice! Take a look at the low profile charm of BMW Z3!
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system. It is actually similar to air shock absorber The principle is very similar to the common shock absorber, coil spring + shock absorber, except that by changing the volume of the air chamber (up and down direction), the distance between the car body and the ground can be adjusted, and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the vent hole of the shock absorber can be changed by the motor, so as to adjust the damping force of the shock absorber. Therefore, the air shock absorber can often provide better performance Performance, huh! So confident!
