查看: 623|回复: 0
当之无愧的低趴黑武士宝马I8气压避震改装实现超跑的贴地姿势
发表于 2021-4-13 15:02:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Worthy of the low lying Black Warrior BMW I8 air pressure shock absorber refitted to achieve super running close to the ground posture
全新宝马i8是混合动力双门超级跑车,全新宝马i8采用了动感的前保险杠和经典的散热格栅设计,传承了宝马一贯的家族理念。全新宝马i8超级混合动力双门跑车的预计起售价为200,000美元(约合人民币126万元)。
备受关注的宝马i8刚刚正式发售不久,德国两家改装厂已经迫不及待地发布了他们对于宝马i8改装方案的渲染图,想用这个走在实车前面的改装概念设计。据悉,宝马i8于2014年9月在国内正式上市,在没有实车的情况下,两家改装厂的设计吊足了车迷们的胃口。
The new BMW I8 is a hybrid two door super sports car. The new BMW I8 adopts dynamic front bumper and classic heat dissipation grille design, inheriting BMW's consistent family concept. The new BMW I8 super hybrid coupe is expected to start at US $200000 (about RMB 1.26 million).
Shortly after the official launch of BMW I8, two German refitting plants can't wait to release their renderings of the refitting scheme of BMW I8. They want to use this refitting conceptual design which is in front of real cars. It is reported that BMW I8 was officially launched in China in September 2014. In the case of no real car, the design of the two modification plants has aroused the appetite of the car fans.
在电影《谍中谍4》里,全新宝马i8混合动力双门超级跑车给人留下了深刻的印象。 德国两家改装厂已经迫不及待地发布了他们对于宝马i8改装方案的渲染图,想用这个走在实车前面的改装概念设计。 可见i8改装的吸引力!改装AIRBFT气压避震的宝马i8更是将它的姿态展现的淋漓尽致,威武霸气的姿态我相信不必电影里给人留下的印象浅!下边就来欣赏一下它的极致姿态!
In the movie spy 4, the new BMW I8 hybrid two door super sports car has left a deep impression on people. Two German refitting factories can't wait to release their renderings of the BMW I8 refitting scheme. They want to use this refitting conceptual design which is ahead of the real car. The attraction of I8 modification can be seen! The BMW I8 refitted with airbft pneumatic shock absorbers shows its posture incisively and vividly. I don't think it's necessary to leave a shallow impression in the film! Let's enjoy its extreme posture!
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system. It is actually similar to air shock absorber The principle is very similar to the common shock absorber, coil spring + shock absorber, except that by changing the volume of the air chamber (up and down direction), the distance between the car body and the ground can be adjusted, and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the vent hole of the shock absorber can be changed by the motor, so as to adjust the damping force of the shock absorber. Therefore, the air shock absorber can often provide better performance Performance, huh! So confident!
