查看: 573|回复: 0
“豪华互联网性能座驾”名爵6改装气动避震悬挂演绎姿态效果
发表于 2021-4-12 16:32:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
全新名爵6是上汽名爵推出的“感性力”概念车MG E-Motion的首款量产车型,于2017年11月3日正式上市。  新车配备“多重健康防护系统”,通过高效过滤、抑制病菌、杀灭病菌“三步走战略”,综合过滤杀菌效果达到99%,实现“N99级别”的车内空气质量安全效果,为驾乘人员提供高标准安全防护。
The brand new mg e-motion 6 is the first mass production model of Mg e-motion, a "sensibility" concept car launched by SAIC mg, which was officially launched on November 3, 2017. The new car is equipped with "multiple health protection system". Through the "three-step strategy" of high-efficiency filtration, inhibition of bacteria and killing bacteria, the comprehensive filtration and sterilization effect reaches 99%, realizing the "n99 level" air quality safety effect in the car, and providing high standard safety protection for drivers and passengers.
全新名爵6是基于概念车打造的首款量产车,自然在外观造型上吸取了不少概念车的设计元素,现在的轿车颜值都很高,所以提车到手首先要做的的就是降低车身,所谓一低遮百丑吗,看看名爵6改装AIRBFT气动避震悬挂的魅力姿态!
The new mg 6 is the first mass production car based on the concept car. Naturally, it has absorbed a lot of design elements of the concept car in the appearance. Now the car has a high appearance value, so the first thing to do when you pick up the car is to reduce the body. Is the so-called "one low cover one hundred ugliness?" take a look at the charming posture of Mg 6 refitting airbft pneumatic suspension!
AIRBFT专用气囊:
Airbft airbag:
