查看: 595|回复: 0
九代雅阁改装气动避震瞬间提升颜值利器
发表于 2021-4-12 16:05:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
九代雅阁改装气动避震瞬间提升颜值利器
Nine generation Accord refits pneumatic shock absorber to improve appearance instantly
第九代雅阁超越了传统意义上的换代概念,是真正意义的“超级雅阁”,荟萃Honda全球领先技术,以梦想动力科技、极致驾悦科技以及豪华座舱科技三大创世科技展现“科技全武装”座驾的非凡魅力,以全价值进化的综合实力强势刷新行业标准。
The ninth generation Accord is beyond the traditional concept of generation change. It is a "super accord" in the true sense. It integrates Honda's global leading technology, and shows the extraordinary charm of "technology fully armed" car with three creational technologies of dream power technology, ultimate joy driving technology and luxury cockpit technology, and refreshes the industry standard with the comprehensive strength of full value evolution.
To pursue the dream in your heart is like seeing the girl you like. You can't restrain the impulse. So is HF style pneumatic shock absorber. The moment you lie down is so beautiful. The impulse in your heart can't be controlled like sneezing! Too many fans of pneumatic shock absorbers are only interested in hiding wheels, trimming and leveling, but the hard tube link of trunk modeling is also an art! The essence of art is taste, persistence, eternity, wisdom, painstaking efforts... Understand it, love it... Respect our spirit!
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system. It is actually similar to air shock absorber The principle is very similar to the common shock absorber, coil spring + shock absorber, except that by changing the volume of the air chamber (up and down direction), the distance between the car body and the ground can be adjusted, and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the vent hole of the shock absorber can be changed by the motor, so as to adjust the damping force of the shock absorber. Therefore, the air shock absorber can often provide better performance Performance, huh! So confident!
